Friday, May 3rd 2019, 7:59am
Wrong zoom level with Bing maps
I use krpano with the Bing maps plugin and vtourskin. vtourskin.xml has the following global settings:
<skin_settings maps="false" maps_type="bing" maps_bing_api_key="" maps_google_api_key="" maps_zoombuttons="false" ...
In the local XML-File merano.xml, 6 scenes are defined with these local skin settings:
<skin_settings url.flash="../plugins/bingmaps.swf" maps="true" maps_type="bing" bingmaps="true" maps_bing_api_key="...key..." lat="46.706330" lng="11.176903" maps_zoombuttons="true" zoom="15" ...
Calling the Bing map, the map is centered and all 6 markers are shown, but with a really low and bad zoom level. Not 15 as wanted.
What settings are wrong which settings I have to choose?
PS: Everything works if I change some settings for the Google maps plugin. But it should work with Bing maps!
Thank you.
Sunday, May 5th 2019, 6:32pm
Ok, I understand - krpano died ...
Bad for registered users ...
toosten
Occupation: freier Software-Entwickler ( HTML, JS, PHP, JSP, Flash, AS3, C++, Java, krpano, ---)
Monday, May 6th 2019, 6:45am
Hab mich mit bing noch nicht beschäftigt, aber das Beispiel sieht anders aus: https://krpano.com/plugins/bingmaps/#examples
Luca Vascon
Beginner
Occupation: VR under any aspect
Friday, July 12th 2019, 3:29pm
Hi, same problem with bing maps here! :-)
Krpano did not die, Klaus is working h24 on a new version, I suppose.
Monday, October 21st 2019, 12:43pm
Hallo,
ich habe das selbe Problem.
Wo kann man den Zoomlevel für Bingmap höher setzen?
Ich nutze nur das vtour multires dorplet.
Also die Standdard KRPano Tools. Keine selbts zusammengestrickten XML Scripte.
Gibt es schon eine Lösung?
LG
Volker
