Wednesday, October 30th 2019, 6:11pm
How can I turn off infinity increase or decrease hlookat?
is it possible to block decrease(turn left) and increase(turn right) horizontal value (view.hlookat). Currentlly, when I turn left, hlookat decreasing for infinity!! I would like obtain value for turn left ( 0 -179) and for turn right ( 0 179) and whenever value beyound -179 or 179 the value toggle from positive to negative or negative to positive. I hope I explained well enought for you to understand.
Greetings!
Alexey Tkachenko
Professional
Occupation: Interpreting, Building virtual tours
Thursday, October 31st 2019, 8:37am
Hi)
I guess it might be like this:
<events name="update_hlookat_values_event" keep="true" onviewchanged="update_hlookat_values();" />
and action
<action name="update_hlookat_values" >		if(view.hlookat GT 180, set(view.hlookat, -179));		if(view.hlookat LT -179, set(view.hlookat, 180));		trace(view.hlookat);	</action>
Regards,
Alexey
Sage
Thursday, October 31st 2019, 10:49am
adjust hlookat is your friend here.
https://krpano.com/docu/actions/#adjusthlookat
Depends how you want to use it of course ... but something like this:
https://www.virtualtuur.com/krpano/120/e…/adjusthlookat/
    <layer name="adjustedhlookat" keep="true" type="text" align="right" html="" />
    <events name="fixview" keep="true" onviewchanged="DoLookat();" />
    <action name="DoLookat" type="Javascript"><![CDATA[
        krpano.call("adjusthlookat(0);");
        var hl = krpano.get("view.hlookat");
        var h = hl.toFixed(0);
        krpano.call("set(layer[adjustedhlookat].html, " + h + ");");
    ]]></action>
Hope it helps!
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
Thursday, October 31st 2019, 11:45am
modulo is your friend :)
trace('hlookat = ', view.hlookat, ' = ', calc(view.hlookat % 180));
... ups seems calc does not support modulo and its not completely right anyway ...
but you can also do it with action code
mod(myhlookat, view.hlookat, 360);
if(myhlookat LT 0, add(myhlookat, 360)); // limit to 0-360
if(myhlookat GE 180, sub(myhlookat, 360)); // shift value to ±180 (optional)
uh, hope that's right *g* *rolleyes*
This post has been edited 7 times, last edit by "indexofrefraction" (Oct 31st 2019, 1:39pm)
Friday, November 1st 2019, 12:30am
thanks you guys :) I got it :))
Cheers
Friday, November 1st 2019, 7:46am
i think tuur was right :
adjustlookat(0); will directly set view.hlookat to ±180
that is the perfect solution
