mc360photo
Trainee
  • "mc360photo" started this thread
Occupation: Photographer
Tuesday, November 12th 2019, 5:16pm
How to use in krpano the Google Photo Sphere metadata
I am getting wrong result using krpano 1.20.2 to generate VTour from images with Google Photo Sphere metadata.
I used the default MAKE VTOUR (MULTIRES) droplet passing an image that has following metadata:
Cropped Area Image Height Pixels: 3000
Cropped Area Image Width Pixels : 6720
Cropped Area Left Pixels : 0
Cropped Area Top Pixels : 0
Full Pano Height Pixels : 3360
Full Pano Width Pixels : 6720
Initial Camera Dolly : 0.0
Initial Horizontal FOV Degrees : 90
Initial View Heading Degrees : 23
Initial View Pitch Degrees : 0
Initial View Roll Degrees : 0
Pose Heading Degrees : 23.07
Pose Pitch Degrees : 0.0
Pose Roll Degrees : 0.0
Projection Type : equirectangular
Stitching Software : mc360photo
Use Panorama Viewer : True
As you can see the image is a full 360° panorama with nadir section cropped; metadata tells that image is starting from Zenith (Cropped Area Top Pixels: 0) but is limited in height at 3000px (Cropped Area Image Height Pixels: 3000) instead of the 3360px of the full sphere (Full Pano Height Pixels: 3360)
But krpano create a tour.xml that has the horizont in the middle of the image (1500px from the top) instead at the proper position at 1680px from the top. This is the generated <view> element in the tour.xml:
<view hlookat="23.1" vlookat="0.0" fovtype="MFOV" fov="120" maxpixelzoom="2.0" fovmin="70" fovmax="140" limitview="range" vlookatmin="-80.357" vlookatmax="80.357" />
Is it possible to generate automatically a correct VTour from images with the Nadir part cropped and Google Photo Sphere metadata properly set?
Thanks for help
Marco
Similar threads
