21
Friday, October 5th 2018, 12:42am
how can I put a button inside the html to close html div?
see the 'Here a link for testing the krpano JS API' part in the example.
It shows how to call any krpano code and that can be also used to remove or hide the layer (e.g. call removelayer or set visible to false).
Hi Klaus
"Here a link"
I don´t see it
Suso
tmhok has attached the following image:
Fernando
Occupation: Architect, Photographer, Programmer.
22
Tuesday, November 6th 2018, 6:07am
solved: modify style for handheld device
Hi, this is about the klaus example "div inside krpano" and the user indexofrefraction code in order to modify the text of div section for handheld device:
I modified the project for working with styles in HTML file instead multiple styles lines in .xml, example:
old xml (witout use class) :
<data name="info"><![CDATA[
<span style="text-decoration:none;cursor:pointer;font-size:16px;" >
example1
</span><br><br>
Solution by indexofrefraction user, for change text size if handheld device:
var ishandheld = document.getElementById('krpanoSWFObject').get('device.handheld');
var fs = (ishandheld == true || ishandheld == 'true') ? 20 : 16;
div.innerHTML = args[1].replace(/font-sizeW:Wd+px/g, 'font-size:'+fs+'px');
current xml:
<span class="panos">
example1
</span><br>
In current html add style definition:
<style>
.panos { color:#B6D1F0;text-decoration:none;cursor:pointer;font-size:1rem }
.panos_handheld { color:#B6D1F0;text-decoration:none;cursor:pointer;font-size:1.5rem }
</style>
For change the chain class="panos", with class="panos_handheld" if the device is handheld, my solution is:
var fs = (ishandheld == true || ishandheld == 'true') ? 'panos_handheld' : 'panos';
div.innerHTML = args[1].replace(/class="panos"/g, 'class='+fs);
(100% inspired (almost copied) in solution of indexofrefraction user *thumbsup* ) Thanks!
Fernando
This post has been edited 1 times, last edit by "Fernando" (Nov 7th 2018, 1:16am)
Fernando
23
Tuesday, March 26th 2019, 10:00am
[solved] ...get the current scroll position
Hi. if you need to known the current scroll position:
1) set id to the div element:
<action name="add_html_code" type="Javascript"><![CDATA[
		var div = document.createElement("div");
		// basic styles to fit into the layer size and allow scrolling:
		div.id = "mylist";
		div.style.width = "100%";
		div.style.height = "100%";
		div.style.overflow = "auto";
		div.style.boxSizing = "border-box";
		div.style.padding = args[2] ? (args[2] + "px") : "0";
(...) continued with original klaus code
2. Create js action:
<action name="show_scroll" type="Javascript">
<![CDATA[
var name = "list_scroll";
list_scroll=document.getElementById('mylist').scrollTop
krpano.set("myscroll", list_scroll);krpano.showlog();krpano.trace(get(myscroll));
3. Create layer for show scroll position:
<layer name="show_scroll"
type="text"
x="10"
y="10"
html="click to show scroll position"
onclick="show_scroll();"
Finish, now you can see the current scroll position for coding.
Fernando
This post has been edited 3 times, last edit by "Fernando" (Apr 4th 2019, 2:35pm) with the following reason: solved
Sage
24
Thursday, May 2nd 2019, 3:21pm
edited
...never mind...
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
ramirox3
Occupation: photographer
25
Thursday, May 2nd 2019, 11:07pm
ERROR: show_scroll - TypeError: krpano.showlog is not a function
Fernando
26
Friday, May 3rd 2019, 3:49pm
working example
This is the full example. To use:Change the scroll position, then Press first button to copy this position, change again the scroll position, press the second button to restore the saved position.
Fernando
PD.
How to post examples as this without to remove license or encrypt xml?
Fernando has attached the following file:
27
Saturday, May 25th 2019, 4:28pm
This line: onloaded="add_html_code(get(data[html_example_code].content), 10);"
How can I make this an onclick event on a hotspot? I've tried to add the add_html_code to set(layer[html_div]....). But I cant figure out how to make it work.
Example:
<hotspot onclick="Too here --> "/>
<layer name="html_div" onloaded="Move this --> add_html_code(get(data[html_example_code].content), 10);" />
<data name="html_example_code">
<![CDATA[ ... ] ]>
</data>
This post has been edited 3 times, last edit by "klaea" (May 29th 2019, 2:51pm)
Red
Trainee
Occupation: Virtual tour creator, VR app developer
28
Monday, July 8th 2019, 9:44am
I'm also trying to call the action in a hotspot onclick like so but the data doesn't populate the div.
js(add_html_code(get(data[html_example_code].content), 10));
Is there anything else I need to add to be able to get data to populate the div onclick?
It currently only seems to work in the onloaded attribute of the html_div layer. I know I can have multiple html_div layers with separate data applied to each onloaded.
But is there a way to use just the one html_div layer and add different divs to the layer?
Thanks for any help
Red
This post has been edited 1 times, last edit by "Red" (Jul 8th 2019, 3:27pm)
29
Friday, November 22nd 2019, 8:38pm
or mobile
there were recently a few requests about how to bring a html div element into krpano and allow using the 'native' browser-based scrolling (e.g. by mouse-wheel, scroll-bars or touch-controls) inside it.
Just adding html-code would be possible also by using the textfield plugin and scrolling could be added by using the scrollarea plugin, but for letting the browser handle the scrolling it gets a bit more tricky because in this case the event-handling between krpano and the browser would need to get 'coordinated' correctly.
Therefore here a full example:
Example
XML Source
Is uses a normal container element puts any kind of html-content inside it.
I'm also considering bringing that functionality directly into krpano, maybe as extended textfield or as layer with type="html" or something like that.
Is it possible to change the width of the scroll and its color on the mobile?
30
Saturday, November 23rd 2019, 7:50am
I tried it and it works
<div id="close" onclick="document.getElementById('krpanoSWFObject').call('set(layer[html_div].visible,false); set(layer[html_div].enabled,false);')" >
    <img src="close.png"  style="width:20; height:20px;  cursor:pointer; float:right;" />
</div>
Or so
<img src="close.png" style="width:20; height:20px; cursor:pointer; float: right;"
     onclick="document.getElementById('krpanoSWFObject').call('set(layer[html_div].visible,false);set(layer[html_div].enabled,false);')"/>
I didn’t notice *smile* . Reply to post
This post has been edited 1 times, last edit by "San7" (Nov 23rd 2019, 10:22am)
