Wednesday, December 4th 2019, 12:57pm
Dynamic hotspot
Can I use an action to dynamically add another folder to the hotspot's image path to dynamically change it?
Sage
Wednesday, December 4th 2019, 1:30pm
yes of course that is possible.
Can you be a bit more specific? so we can help you on the code.
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
Thursday, December 5th 2019, 1:22am
if(_lang == 'ko',
set(hotspot.tag, ko);
show_hotspots();
if(hotspot.tag == 'ko',
trace('url=', get(hotspot.url));
if(_lang == 'en',
I want to get the path of the entire hotspot of the current scene and manipulate part of the path.
The current hotspot path is
<hotspot name = "pension_001" url = "bar_content.png tag =" "/>
I want to put the folder path part before bar_content.png using action.
Thursday, December 5th 2019, 2:30am
if(_lang == 'ko',
show_hotspots();
for(set(i,0), i LT hotspot.count, inc(i),
set(hotspot[get(i)].visible,true);
calc(path, 'img/english/' + hotspot[get(i)].url);
set(hotspot[get(i)].url, get(path));
if(_lang == 'en',
This is done by adding the folder path before the path of the hotspot. thank you. *smile*
