Thursday, December 12th 2019, 11:33am
Depth map rendered from blender deforms scene not so well
I exported depth map from blender and scene is not deformed well.
Here is the depth map, image output, node setting and result :
scene
node
rendered image and depth map
result
This post has been edited 2 times, last edit by "giangm9" (Dec 16th 2019, 11:56am)
jordi
Monday, December 16th 2019, 10:16am
while there can be many reasons for getting the depthmap images from blender or 3D max or ..., there are still many other reasons to get it form everpano 3D, and not the depthmap image itself but the *.depth file which is the most recommended file format for depth in krpano. It's just the numerical version of the geometry.
find attached the .depth file and the depthmap image generated with everpano 3D.
vs
result using depth format file :
also please find here the screen cast here (just 3 minutes of how to create it)
https://youtu.be/PgKXKYu3qSg
jordi has attached the following files:
  • 0.tif (4.87 MB - 1 times downloaded - latest: Dec 17th 2019, 8:34am)
  • 0.depth (844 Byte - 1 times downloaded - latest: Dec 17th 2019, 8:34am)
  • 0.stl (7.22 kB - 1 times downloaded - latest: Dec 16th 2019, 2:24pm)
everpano.com step beyond 360
Monday, December 16th 2019, 10:37am
My target is generate depth map/stl/depth automatically, because the quantity of blender files is very big.
Is there any way to export good .stl or .depth files from blender ?
I know blender can export STL but the result is not good as manualy
https://krpano.com/forum/wbb/index.php?p…&threadID=17198
This post has been edited 1 times, last edit by "giangm9" (Dec 16th 2019, 11:08am)
Monday, December 16th 2019, 11:29am
first you must understand, that a depthmap-image is internally translated to geometry, too.
and this is most likely always worse than a real 3d-depthmap. (visible grid in your pictures)
second, also 3d-depthmaps should be as lightweight as possible.
so it is better to create a minimal geometry in the 3d app than to use a rendered image-depthmap.
you can use everpano, but if you have your 3d-model already in blender i'd do it there, that is 5mins of work
Monday, December 16th 2019, 11:44am
Sorry for my lack of knowlege :D
I know that stl/depth data is the best way to "deform" panorama mesh. But export stl/depth data from a blender file programatically is my target. Blender dont have depth file exporter. Exporting scene to STL file is possible, but result is not same as what I see on blender : https://krpano.com/forum/wbb/index.php?p…&threadID=17198
So my choice is depth image, and I think just a little change in node setting or some parametter in krpano may give me a good enough result.
By the way, can I request a tool from krpano to help me export depth/STL from blender ? How does it may cost ?
P/S : the scene I that i used to ask is just a sample, in my case, my scene is much larger and the quanity of scenes is very big
Monday, December 16th 2019, 2:01pm
I'm sure this is only an export problem... with the correct settings it should work to export an stl from blender
(or export another format and convert in another 3d application)
just be sure that your coordinate system has its center where your camera is. (camera has to be at 0,0,0)
i think depthmap-images are only the last resort... stl is always better
and you cant use the model you use for the rendering, you need a really minimal version for the stl
jordi
Monday, December 16th 2019, 2:21pm
You should not only take into account the camera location which of course is basic to be correctly set at (0,0,0) location of your scene.
But also take in care the coordinate system that needs to fit with the krpano.
*.depth is even better ;)
Look at the values of weight from the attached files above
depth = 844 bytes
stl = 7.2 kb
When the geometry get more complicated also it does the difference from format weight.
Kind regards
Tuesday, December 17th 2019, 3:07am
depth = 844 bytes
stl = 7.2 kb
Kind regards
But automatically export STL/.depth from blender to fit with krpano is not easy. May I order krpano team to write an addons for that ? How much it may cost ?
jordi
Tuesday, December 17th 2019, 1:38pm
yes that's true, I have been deeply cheking it with some projects I created in blender for testing, and the stl generated by blender needs to be manipulated in there many aspects. But I have understood what need to be done in order to transform them into krpano depth system.
I could writte a blender addon for doing so, and also it could automatically render all camera positions at once, and some more cool stuff like creating all the xml files necessary for krpano to play the project with global value positions and so on, but is many people interested in such addon ?
Some people in the forum using blender ?
Sage
Tuesday, December 17th 2019, 2:48pm
Quoted
Learning.. but very novice and just started..
Can be very useful though.. but also needs much attention and focus.
I would be interested a blender add on .. i think.
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
Tuesday, December 17th 2019, 4:51pm
Incase I keep using depth image, is there any way to adjust image to make my scene looks better ?
jordi
Tuesday, December 17th 2019, 5:25pm
Yes, range is very important, so setting correctly what color is 0 distance and where black is maximum distance will make your depthmap more accurate.
So in your node window, you should set up with precision minimum and maximum distance.
But again, depthmap images should only be used to perform small movements, and *.depth format to freely move around.
Hope it helps
