jeromebg
Professional
  • "jeromebg" started this thread
Occupation: Photographer
Monday, February 10th 2020, 8:52pm
Stange zoom behaviour since 1.20
HI,
I have 2 tours using the same UI, one runs krpano 1.19pr16 and the other one krpano 1.20.
On the first one if you scroll over a bing map to zoom in or out it works as expected, but on the second one it shift the map left or right wehn zooming ?
Tried also with the latest 1.20.4 with the same issue.
Don't know if it comes from the bing map plugin or the area krpano feature ?
You can try here (clic on the compass bottom right) :
1.19pr16 : https://www.360images.fr/vercors/index.html
1.20 : https://www.360images.fr/360/suisse/moiry/index.html
THX
jeromebg
Professional
Tuesday, February 11th 2020, 1:50pm
Done some more tests, so area is not the problem.
When map is 100% screen width it works as expected, but when map is for exemple 30% width the the zoomtocursor (which can't be disabled or I dodn't found how) os wrong and behaves like if map was 100% of the screen.
Barebone :
http://360images.fr/barebone_bingmap/
http://360images.fr/barebone_bingmap/?onstart=set(plugin[map].width,100%)
Tuesday, February 11th 2020, 5:41pm
this is a bug, thanks for reporting!
The reason is the new custom mouse-wheel handling in the 1.20 bingmaps plugin. Previously the build-in mouse-wheel handling of the bingmaps-API was used, but that one had cross-browser bugs and problems wit the event-flow (e.g. it had zoomed/scrolled also the elements behind the map).
This will be fixed in the next krpano release.
Similar threads
