San7
  • "San7" started this thread
Occupation: coding in krpano
Wednesday, July 31st 2019, 12:02pm
Menu creation
Hello!
This is a universal menu in which you can create and customize the structure and design, assign the necessary actions to the buttons. The number of elements and depth of attachments depends on Your decision.
  • By default, the menu is created automatically as a "thumbnail bar".
  • Set the required number of lines in the menu and assign them your actions.
  • Create the number of groups you need.
  • Create groups within groups. You can set the depth of nested lists.
  • When the window height is full, the menu scrolls automatically.
  • Adjust menu width, color, transparency.
  • Change You own design of the buttons.
  • You can change the design of the individual button.
  • Assign icons to buttons.
  • You can create thumbnail bar.
  • Enter text in two languages. The language switch button will appear automatically.
Example 3D
Description on the site
http://novosibpano.ru/Plugins/Menu_en.html
San7 has attached the following image:
This post has been edited 3 times, last edit by "San7" (Oct 21st 2019, 2:58pm)
Tuesday, October 15th 2019, 11:02am
Works Menu with 1.20?
Suso
San7
Tuesday, October 15th 2019, 11:07am
I have not tested, but should work.
I make another menu and it works in 1.2
I haven’t done a translation into English yet, but you can look with the help of a translator and download a test version
Here is a description
http://novosibpano.ru/Plugins/Menu_ru.html
This post has been edited 1 times, last edit by "San7" (Oct 15th 2019, 11:29am)
Tuesday, October 15th 2019, 11:22am
I like it *squint*
Tuesday, October 15th 2019, 11:24am
What will be the price?
San7
Tuesday, October 15th 2019, 11:30am
29 Euro is spinning in my head *smile*
This is a test option, after which it will be more expensive
This post has been edited 1 times, last edit by "San7" (Oct 15th 2019, 12:33pm)
Tuesday, October 15th 2019, 11:42am
when you check that it works for the new version of krpano communicate it *thumbsup*
San7
Tuesday, October 15th 2019, 12:06pm
You can now download the demo version and check on your tour
Tuesday, October 15th 2019, 12:09pm
San7
Wednesday, December 4th 2019, 3:23pm
Klaus, thanks for the quick placement of the plugin on your site! *thumbsup*
https://krpano.com/plugins/userplugins/menu/#top
Wednesday, December 18th 2019, 8:05am
Two questions
Hi!
I just bought the plugin and I have two questions:
1. When the first scene is loaded, the check mark of this scene is not activated until I return to the same scene after seeing other panos. How do I activate the mark since loading the first scene?
2. With Bing Maps, after loading the first scene, if I do not click on the button to open the map and i change the scene, the map does not update the spot in any of the following scenes, until i click on the button map. Do you know if the problem is that the menu button does not update the spot on the map?
best regards!
San7
Wednesday, December 18th 2019, 8:48am
Hello!
If at start you have the first scene opened, and the thumbnail of this scene is the first in the menu, then you can write it like this:
<scene name="scene_1"... onstart="set(layer[marc_prosm_lin_1].alpha,1)"
You must understand that the plugin is necessary in order to create your own button structure and assign them an action (this does not necessarily open the scene).
Setting buttons in the form of thumbnails and calling up a scene by clicking on it means that when you click on the menu button, we open the scene and nothing more! Everything that is additionally associated with the opening of scenes must be created and assigned to the button yourself.
And the menu has no feedback, because everyone can use their skin with their needs, as well as a panorama without scenes.
I want to note that the description describes the functionality of the menu and your access to a fully working demo version, which you can experience as much as possible.
This post has been edited 1 times, last edit by "San7" (Dec 18th 2019, 9:28am)
Tuesday, February 4th 2020, 10:26pm
Catering for tours that have dynamic elements
I've recently purchased your Menu plugin and have been able to change the look and feel fairly easily by following your instructions, thanks! It is well designed and a pleasure to use.
I do have a couple of things I would like it to do and hope that you can help me:
1: When you click on a list item, the click action happens and then the text on the button becomes 'greyed' and stays that way. Is it possible to disable this change to the text or make it happen only on the last active button?
2. Is it possible to dynamically change the menu buttons while the tour is active? e.g. assign a different description and action to a button? Some floors in my tours have different features and so it would be useful to enable/disable menu elements depending on the floor in use.
Thanks and Regards
San7
14
Wednesday, February 5th 2020, 4:33am
Hello
Thanks! I'm glad you like the plugin!
I am answering the questions:
1. Do not put a semicolon in the action button click="action()"
2.For example, you have written:
<menu_v name="menu_1_2" title_1="test" .. click="trace(555);" />
To change a dynamic action, you can perform an action:
set(layer[lin_1_2].onclick,trace(777); );
This post has been edited 2 times, last edit by "San7" (Feb 5th 2020, 4:59am)
15
Thursday, February 6th 2020, 8:39pm
Many thanks for your prompt reply.
I appreciate your help with this, San7. Removal of the semicolon definitely works great. I shall experiment with the layer changes over the next few days. *g*
Kind Regards
16
Thursday, February 6th 2020, 9:15pm
Hi San7,
I've experimented with changing dynamic actions and it works perfectly, thank you.
How do I change the title of the menu line item so that it matches the action?
I've tried setting title_1 as with set(layer[lin_4_1].title_1, 'new option' );); which doesn't work. I also tried just title instead of title_1 with no luck.
Is there a special setting that I need to use?
Thanks again!
San7
17
Friday, February 7th 2020, 2:26am
lin_4_1 - This is the "container" layer
txt_menlin_4_1 - Text layer in this container
Need to write like this:
set(layer[txt_menlin_4_1].html, 'new option');
18
Sunday, February 9th 2020, 2:37pm
Thanks again, San7, that works great!
All he best!
19
Wednesday, February 12th 2020, 5:05pm
Can the menu be hidden after a certain time?
San7
20
Wednesday, February 12th 2020, 5:12pm
Yes, for example, use this command delayedcall(5,hide_m());
