Sage
  • "Tuur" started this thread
Thursday, April 2nd 2020, 11:32pm
IOS 13.4 issues
i just updated to IOS 13.4 on my iphone 11
gyro seems not working anymore,.. in webvr at least..
in normal mode just vertical..
and i also see some things different also on my desktop .. rotated icons.. (?)
Version 13.1 (15609.1.20.111.8)
is there new rules/protocol/bugs?
I checked a few of my own examples that where fine yesterday..
krpano webvr game example seems fine.. i get crazy and/or old..
what is going on?
EDIT: Ahh!
Quoted
part of the release notes:
'Fix: Gyro/WebVR - in iOS 13.4 beta / Safari 13.1 the DeviceMotionEvent is broken and it is unclear if Apple will fix that. Therefore the DeviceOrientationEvent, which is working, will be automatically used as alternative instead on the related systems.'
so i need to update those..
clear..
Apple *cursing*
Tuur *cry*
http://www.virtualtuur.com
Skype:studiotuur
This post has been edited 2 times, last edit by "Tuur" (Apr 3rd 2020, 12:05am)
Saturday, April 4th 2020, 11:02am
right, that's because a very ugly bug in iOS 13.4.
The gyro and VR controls are using the browsers 'devicemotion' event (by default) to get information about the current device rotation state. And in iOS 13.4 that event no longer reports the gyroscope rotation information, only the acceleration information are available. That makes the gyro/VR control working strangely slow and inaccurate.
I had made a very simplified test-case for Apple here:
https://krpano.com/ios/bugs/ios13-4-b1-gyro/
That bug is there since the very first iOS 13.4 beta versions since a few months and was reported also to Apple a several times of course. All I got back from Apple was that they would need more information or screenshots or videos about the problem, which I also added, but as so often with Apple nothing happened further...
Luckily there is an easy solution, there is also the 'deviceorienation' event, and on iOS it provides the almost same information and still works in iOS 13.4.
Therefore in krpano 1.20.5 that is used by default now for iOS 13.4.
So gyro and VR control keeps working.
Btw - this makes krpano currently the only web-based pano-viewer software that has a VR mode that still works with iOS 13.4 ;-).
Thursday, April 9th 2020, 5:08am
Gyro in iOS 13.4
I updated one of my vtours to 1.20.5, and the gyro is still not functioning, I read that with version 1.20.5 the bug from Apple is fixed, Is this right?
from your message below I read this
Therefore in krpano 1.20.5 that is used by default now for iOS 13.4.So gyro and VR control keeps working.
But is not working,
Only with android I can use the gyro option.
Do I have to change some code to use the gyro option again.
And I have another question, is there an easier way to migrate my 1.19.16 vtours to 1.20.5, because I have to start from the beginning every tour, I mean I have several tours that can't function now in iPhone with IOS 13.4, and I am starting from scratch i.e. using the droplet from the original photos, and then using krpano tools to put hotspot, etc. but I made a lot of changes in the files customizing some things, and is a lot of work, I made the migration of one of these vtours thinking it will be fixed with the 1.20.5 version, but without success.
Any advice will be appreciated.
Thank you *smile*
Sage
Thursday, April 9th 2020, 11:59am
Quoted
But is not working,
can you share a link?
Quoted
I would first start to just change/update the plugin . js files and the viewer js file.
Then check.. and go from there..
btw.. your forum name makes me think you are Dutch.. are you? *g*
Tuur *thumbsup*
Skype:studiotuur
Thursday, April 9th 2020, 12:11pm
The bug above is related to an iOS 13.4 where that the gyro-movement itself is not working correctly (but working) because of missing data.
When the gyro is not working at all, you're probably using HTTP instead of HTTPS.
But that's not krpano or krpano version related.
Update/replace the krpano viewer and plugin files, either manually or by using the update tool. The xml files normally wouldn't need to get changed.
Thursday, April 9th 2020, 10:44pm
Version 1.19.3, that now with IOS 13.4 the gyro icon is missing, before upgrade we can see the virtual tour without problems. Now we can't.
https://deteastvr.com/
Version 1.19.6, unfinished work, transition between http and https to fix the virtual tour function last year, until update of IOS 13.4 where gyro icon doesn't function
https://deteastvr.com/jumex/
Version 1.20.5 test for checking if this version fixed the gyro icon and vr tour (without the index.html page introduction, going directly to our next unfinished work), the gyro icon doesn't function as expected, neither the vrtour using IOS 13.4, but with android there is no problem until now.https://deteastvr.com/jumex2
Mi forum name came from when I worked in Samsung Korea, mi Nic name is Peke, but in Korea all the engineers call me Mr PIk, so I changed it as a nickname since then *cool*
I am Mexican, and live in Mexico City.
Why are you thinking with this nickname I am dutch? Just for curiosity.
Thursday, April 9th 2020, 10:54pm
I am using https since last year problem.
Do I have to modify some code? or add a command to fix that problem?
Thank you for your help and support.
Sage
Thursday, April 9th 2020, 11:49pm
Quoted
I think best, and most save, is to google translate 'pik' dutch-->english
Or whatever..
Sorry.. haha
Our cats name is Pickle.. we call him Mr Pik..
The neighbours had to get used to that a bit.. haha
Tuur *thumbsup*
Skype:studiotuur
Friday, April 10th 2020, 4:31am
Or whatever..
Sorry.. haha
Haha, I will change my nickname. It was a surprise.
Thanks for the info.
Friday, April 10th 2020, 4:34am
Could you see the problem in my vr tours?
What can I do to fix the problem, do I need to change some code or something else?
I update to 1.120.5 thinking it will be solved.
Thank you
Friday, April 10th 2020, 10:47am
The version in that link is still 1.20 and not 1.20.5 and it is not clear/visible if you have updated the plugins too.
Friday, April 17th 2020, 8:56am
Quoted from "mrpik"
Thank you for your replyI downloaded 1.20.5, and started from scratch te new vtour.
And if I saw the xmls created, they said version 1.20 not 1.20.5
And I can't see is functioning with iPhone with IOS 13.4
I don't know what to do now.
Regards,
Sage
Friday, April 17th 2020, 9:16am
Quoted
That is normal.
Quoted
You encrypted all so it is hard to see which versions of the plugins you use.
I think it is not needed in this case to encrypt.
Are you sure all plugin js files in the plugin folder are also 1.20.5?
And the viewer js too? (tour.js)
i see in the log:
INFO: krpano 1.20 (build 2019-09-02)
that is an old version!!!
that should be:
INFO: krpano 1.20.5 (build 2020-03-05)
or even better use the last 1.20.6 update.
Tuur *thumbsup*
Skype:studiotuur
14
Thursday, April 23rd 2020, 8:37pm
Thanks Klaus and Tuur
I upgraded to version 1.20.6 and now it is working with IOS 13.4 *g*
15
Tuesday, May 12th 2020, 12:03pm
Gyro in iOs 13.4 in older pano's
I have upgraded krpano to 1.20.5 and it solves the gyro-issue in iOs 13.4! Tnx! But what about all the older pano's? It is a hell of a job to convert all the others to 1.20.5. Is it possible to add a line to tour.xml or a file that solves the gyro-problem for older pano's?
16
Tuesday, May 12th 2020, 4:53pm
normally replacing the tour.js should do the thing.
its a nuisance, but with all the weird things the browsers and apple/ios comes up
it is necessary to update older tours once in a while.
