vasin
Trainee
  • "vasin" started this thread
Occupation: photographer
Monday, July 1st 2013, 12:19pm
background sound
Hello Everyone,
I never tried adding sound to the virtual tours, so it is my first time. And I need your help.
My virtual tours are generated automatically by the make vtour tool.
I tried adding this code
<!-- load the soundinterface plugin --> 	<plugin name="soundinterface"	    	url="http://at-bangkok.com/virtualtours/snc/plugins/soundinterface.swf"	    	alturl="http://at-bangkok.com/virtualtours/snc/plugins/soundinterface.js"	    	rootpath=""	    	preload="true"	    	keep="true"	    	/>
	<!-- start playing the sound -->	<events name="currentpano"	        onnewpano="playsound(bgsnd, 'http://at-bangkok.com/virtualtours/snc/1.MP3|http://at-bangkok.com/virtualtours/snc/1.wav', 0);"	        onremovepano="stopsound(bgsnd);"	        />
	<!-- button to pause the sound: -->	<plugin name="snd" url="http://at-bangkok.com/virtualtours/snc/soundonoff.png" align="topleft" x="10" y="10" alpha="0.25" scale="0.5" onover="tween(alpha,1);" onout="tween(alpha,0.25);"	        crop="0|0|50|50"	        onloaded="if(ismobile,set(scale,1));"	        onclick="pausesoundtoggle(bgsnd); switch(crop, 0|0|50|50, 0|50|50|50);"	        />
to the both tour.xml and vtourskin.xml but it don't work. The soundonoff.png doesn't even show.
Please let me know what I did wrong. the vtour link is http://at-bangkok.com/virtualtours/snc/
Any input would be appreciated. Thank you!
Best regards
VAsin
vasin
Trainee
Tuesday, July 2nd 2013, 8:32am
The audio dose work on Android 4.2 and IPAD, but the sound on off button doesn't display.
BUT it does not work on the PC.
I can't figure out why the "sound on off" does not appear?
<plugin name="soundinterface"	        url="plugins/soundinterface.swf"	        alturl="plugins/soundinterface.js"	        rootpath=""	        preload="true"	        keep="true"	        />
	<!-- start playing the sound -->	<events name="currentpano"	        onnewpano="playsound(bgsnd, '1.mp3|1.wav', 0);"	        onremovepano="stopsound(bgsnd);"	        />
	<!-- button to pause the sound: -->	<plugin name="snd" url="soundonoff.png" align="lefttop" x="10" y="10" alpha="0.25" scale="0.5" onover="tween(alpha,1);" onout="tween(alpha,0.25);"	        crop="0|0|50|50"	        onloaded="if(ismobile,set(scale,1));"	        onclick="pausesoundtoggle(bgsnd); switch(crop, 0|0|50|50, 0|50|50|50);"	        />
Please any input? the tour.xml file is attached
vasin has attached the following file:
  • tour.xml (10.26 kB - 204 times downloaded - latest: Mar 5th 2023, 5:29pm)
Tuesday, July 2nd 2013, 12:00pm
the "currentpano" <events> and "snd" <plugin> elements need a keep="true" to be able to used within the scenes.
Without keep="true" they will be get instantly removed at startup when the first scene will be loaded.
vasin
Trainee
Tuesday, July 2nd 2013, 1:06pm
Klaus,
Thank you so much.
It worked but every time I change a scene, the audio starts over.
Is it possible to have it play continuously and loop when it ends?
	<events name="currentpano"	        onnewpano="playsound(bgsnd, '1.mp3|1.wav', 0);"	        onremovepano="stopsound(bgsnd);"			keep="true"	        />
	<plugin name="snd" url="soundonoff.png" align="lefttop" x="10" y="10" alpha="0.25" scale="0.5" onover="tween(alpha,1);" onout="tween(alpha,0.25);"	        crop="0|0|50|50"	        onloaded="if(ismobile,set(scale,1));"	        onclick="pausesoundtoggle(bgsnd); switch(crop, 0|0|50|50, 0|50|50|50);"			keep="true"	        />
Thank you again
Tuesday, July 2nd 2013, 1:24pm
the event will be called with every new pano,
to play it only once with remove the event after the first call or use the krpano onstart event to play the sound,
e.g.
<events name="currentpano" keep="true" onnewpano="playsound(bgsnd, '1.mp3|1.wav', 0); set(events[currentpano].onnewpano,null);" />
or simply:
<krpano onstart="...; playsound(...);">
vasin
Trainee
Tuesday, July 2nd 2013, 1:43pm
got it
Thank you so much!
Tuesday, December 22nd 2020, 6:14pm
Not working on my project
Hello can you share your tour.xml because i implement same thing on my project but it's not working please help.
