Friday, May 14th 2021, 6:18pm
Open/close description with html
Hello,
i'm using panotour to create a tour and it's set to load the project description on load. Where can i find the code that triggers it, so i can disable? Alternatively can i close it with javascript? The idea is to close the description without re-exporting the tour.
Thanks in advance!
Friday, May 14th 2021, 9:36pm
To disable it onstart in the skin.xml there is an option in the description setting
openatstart="true"
change it to false
To close it call action
closeKolorArea_description()
