bg360
Trainee
  • "bg360" started this thread
Tuesday, September 21st 2021, 6:20pm
Can't zoom for details
Hello,
why the minimal FOV is 120? I can't zoom to see details. And I can't create good references.
Below is shown the max zoom with Everpano 3D. I want to zoom to the red rectangular, but I can't.
Kind Regards,
Mitko
bg360 has attached the following images:
This post has been edited 1 times, last edit by "bg360" (Sep 21st 2021, 6:41pm)
Tuesday, September 21st 2021, 8:55pm
search for maxpixelzoom in the documentation
bg360
Trainee
Wednesday, September 22nd 2021, 5:46am
I’m talking about Everpano 3D, not Krpano!
jordi
Professional
Wednesday, September 22nd 2021, 10:54am
actually when generating the scene internally the fovmax was set to 140, I just modified that setting and also allowed some pixel zoom so you will be able to get closer to details.
Find attached the images that compares both cases
That's changed and will be available in next release.
Thanks and kind regards
jordi has attached the following images:
everpano.com step beyond 360
bg360
Trainee
Wednesday, September 22nd 2021, 4:52pm
Thank you, Jordi!
And few more things:
1. How can I delete a project? I want to remove it from "recent projects".
2. When I accidentally choose file/open I can't close the modal window - I have only options to choose a project or to create a new one. So, I'll lose my recent changes to my open project.
jordi
Professional
Thursday, September 23rd 2021, 1:17pm
If you just remove the project folder, or move it to a new path, or rename it then it will automatically disappear from the recent list in the app
You can still go to menu and save the file, or ctrl + s , but if you would like to remove the modal without reopening the app as a workaround you could open any other modal like render for example ctrl + r and then you have the close button there. Anyway I note it and will add close button in the open project modal.
Kind regards
