Sunday, May 22nd 2022, 6:04pm
Is it possible to not use XML files?
I'm working on a very specific use case for a single pano (at this stage, more panos down the track) and in this use case the XML files are being blocked from loading. I'm wondering if it is possible to put all the XML data (which is pretty minimal) directly into the main HTML file?
jordi
Professional
Tuesday, May 31st 2022, 2:13pm
Yes, it is possible
you can do like this :
var your_xml = "<krpano><preview type='grid()'/></krpano>';
embedpano({xml:null, target:"pano", onready:function(krpano)
	krpano.call("loadxml(" + escape(your_xml) + ")");
from that post
everpano.com step beyond 360
Friday, June 10th 2022, 1:27pm
yes, and by using the loadpanoimage() action:
https://krpano.com/docu/actions/#loadpanoimage
it's even possible to avoid any xml-file or xml-string usage.
Here an example for loading a multires flat-pano:
krpano.image.reset();
krpano.image.flat = {
  url : "tile_%l_%v_%h.jpg",
  multires : "512,1024x512,2048x1024,4096x2048"
krpano.actions.loadpanoimage('MERGE','BLEND(0.5)',function()
  console.log('load call done');
