Friday, June 10th 2022, 10:02am
In the case of "pops example", a pop-up window is opened, and there is no close button in the upper right corner.
Hello, engineer. In the case of "pops example", a pop-up window is opened, and there is no close button in the upper right corner. What is the reason? Thank you.
xml: popups. xml
Popups with iFrames / HTML / Images and a blurred background
A demo of how to blur the background using the Blur Postprocessing Plugin and how to open several different popups (HTML, Websites, Panos, Videos, Images).
Friday, June 10th 2022, 1:12pm
What is the reason?
The answer is in the example code - look for:
optional: add a close button
and remove the comment tags /* and */ around that part.
Friday, June 10th 2022, 3:17pm
Perfect solution, thank you
