loki
Trainee
  • "loki" started this thread
Wednesday, June 23rd 2021, 8:48pm
Paused audio resumes automatically on refocusing browser tour tab in Firefox and Chrome on Win10
Hi all,
my paused sound resumes when using ATL+TAB to get back into the browser tour tab.
Sound plays/streams by onclick on "play hotspot", then gets paused by clicking on "pause hotspot", then I use ALT+TAB to switch to another program, then use ALT+TAB again to get back to the browser tour tab and the problem occurs:
Most of the times (not always), the paused sound resumes automatically without any other user interaction.
Is it possible the browser audio focusing may cause this in Chrome and Firefox?
I tried both streamsound and playsound, tried autopause and autounlock true/false without success.
Maybe a manual autopause action could be a workaround: Once the vtour looses focus, pause the sound and switch play to pause button, but I'm not sure how to achieve this.
Right now I use this rather dirty code:
<hotspot name="snd1play" ... enabled="true" visible="true" onclick="destroysound(s2); streamsound(s1, 's1.mp3|s1.webm', false, 1, stopallsounds();); set(hotspot[snd1pause].visible,true); set(hotspot[snd1play].visible,false);" />
<hotspot name="snd1pause" ... enabled="true" visible="false" onclick="pauseallsounds(); set(hotspot[snd1play].visible,true); set(hotspot[snd1pause].visible,false); set(hotspot[snd1play].onclick, togglesound(s1); set(hotspot[snd1pause].visible,true); set(hotspot[snd1play].visible,false); );" />
Could someone share a hint please?
Thank you!
loki
light_line
Occupation: krpano freelancer || creating ideas & coding them || krpano developer
Friday, July 23rd 2021, 2:20pm
This can be a temporary solution:
Save audio playing status in a variable every time you change it.
Then set the latest status of the audio on the "window.onfocus" event.
I hope this helps you.
Hamid
loki
Trainee
Thursday, November 18th 2021, 12:09am
Thank you very much Hamid for sending me into the right direction.
With soundinterface setting
autopause="true"
below code works to prevent previously paused sound to automatically resume playing on loosing and then focussing the window/tab again:
<action name="listentofocuschange" type="Javascript" autorun="onstart">
	<![CDATA[
		document.addEventListener("visibilitychange", event => {
		if (document.visibilityState == "visible") {
				krpano.call('trace(getfocus));');
				krpano.call('if(audio === null, pauseallsounds(););')
			} else {
				krpano.call('trace(lostfocus));')
... with "audio" being my helper var.
Also with autopause="false" this bug happens @Klaus.
Best,
Max
Thursday, November 18th 2021, 2:32pm
sorry, but I don't understand what you mean or why this is a bug?
Automatically pausing and resuming the sounds when the browser window gets hidden or shown is the intended behavior of the autopause setting.
So far I understand you don't want to the sounds to resume, why?
loki
Trainee
Thursday, November 18th 2021, 3:31pm
sorry for the confusion.
It seems like the autopause="true" setting overwrites the "pauseallsounds();"-action. Even with autopause="true", I expected that audio, which gets paused by the user would still be paused if the user changes tabs and comes back to the tour-tab. The previously paused audio (e.g. onclick audio-hotspot) would then resume unexpectedly, probably because autopause thinks a previously paused audio needs to resume on focussing the tour-tab again, which is misleading.
Interestingly, the same happens with autopause="false".
Bug behaviour step by step:
For autopause="true":
1: Start sound using streamsound(name, ......);
sound starts as expected
2: Pause sound using pauseallsounds();
sound pauses as expected
3: Switch tab/hide browser (Chrome)
tour looses focus, sound still paused as expected
4: Switch back to tour-tab
tour gets focus, paused audio resumes without user interaction unexpectedly
The same happens for autopause="false":
I can create a test later.
Best,
Max
Tuesday, November 23rd 2021, 10:55am
right, this was not working.
There was a bug in howler.js related to streamsound() usage, in this case the pause state is not correctly tracked.
This will be fixed in the next release.
Thursday, August 18th 2022, 8:21pm
Hello,
I have the same problem with all the tours created with Panotour (I have installed latest versions of both PTP and krpano).
Is there any quick fix for this issue?
Lukas
