Monday, January 2nd 2023, 6:40pm
What's wrong with depthmap?
Hello,
Using Unreal 5 panoramic capture (or similar plugin), I rendered panorama of the scene. And... it is Good!
Then I chose to render its depthmap. It was rendered, from the first glance it look OK as well, but when i'm trying to use it - i get some strange distortions :(
Any ideas, what's wrong and how could i fix it?
Thanks,
Tomas
blaztoma has attached the following images:
kme
Occupation: Long time coder, product manager and 3D enthousiast
Tuesday, January 3rd 2023, 11:35am
I used the most basic setup and did not see artifacts.
What does your scene code look like?
Here is mine:
	<view tx="0" ty="0" tz="0"/>
	<scene name="dollhouse" autoload="true" title="hello">
			<sphere url="FinalColor.jpg"  />
			<depthmap url="SceneDepthSm.jpg" />
Result:
Tuesday, January 3rd 2023, 5:02pm
that depthmap image has an uncommon depthmap-mapping.
krpano uses a mapping where the pixel-values scaling a unit-sphere, but your depthmap-image seems to define a distance directly with an additional exponentiation.
In krpano 1.21 (release soon) there are additional depthmap setting, there such depthmap-images can be used.
Friday, January 6th 2023, 6:43am
Thank You for efforts and answering!If You are standing in a middle of a scene - the artifacts won't be visible.
Btw, what a dollhouse looks like?
Tomas
Friday, January 6th 2023, 6:50am
Thanks, Klaus!
At least it is clear that the problem is a depthmap.
Eagerly looking forward a new release :)
kme
Friday, January 6th 2023, 10:36am
Tomas
You can have a look *g*
https://i.imgur.com/8uIvzuT.mp4
Friday, January 6th 2023, 1:04pm
Thank You very much!
Yes, I see this implementation has the same problem - cube is distorted.
There are no artifacts inside because of the offset.
Anyway - thanks for trying out!
Tomas
