datofz
Trainee
21
Wednesday, March 4th 2020, 10:30am
Bug correction and Few improvements
Hello,
I've bought it and in use i see 2/3 things:
I use it with group.
  • The offset of the thumbnails in the group in LEFTTOP are too much in the left ( i've 3 panos in the group)
  • Whem the row thumb =2 (not group), and i've only 1 pano, there is a offset of the link to load pano
  • If i delete the close button, the behaviour of the grid is weird.
  • Strong aliasing in thumb border
improvements
  • a button to return in sub group, not dirrectly in first space ?
  • more events or getter : know when this plug in visible (for stopping video not finished for exemple)
In Oculus browser its ok, the thumb not shaking but in firefox reality, its bad.
I think its not the plug but the browser (i've test witout the plug and it a same behaviour.if its possible to repair some bugs et adding this feature, i will be happy.
Thanks, Damien
22
Saturday, January 9th 2021, 2:36pm
Error on mobile
For some reason, on a mobile device, the cursor became unclickable ... https://vrpanorama.ru/tours/elbrusvr/
jeromebg
Professional
  • "jeromebg" started this thread
Occupation: 360 experiences creator
23
Saturday, January 9th 2021, 10:06pm
Strange ?
send me the email you used for buying the plugin and I'll send you latest version (jerome [at] 360images.fr)
24
Monday, January 11th 2021, 6:31pm
Strange ?
panorama07reg@gmail.com
loki
Trainee
25
Saturday, April 24th 2021, 3:48pm
thanks for the plugin Jerome, looks and feels very neat!
Is there an example for use with depthmaps? I'm not sure how to adapt Klaus' Abu Simbel example.
Instead of loading a scene using the VR thumb menu I'd like to use transition-actions, so the coordinates are correct. How could I achieve this?
Also when opening the menu, the bgalpha forms a small black cube at the origin of the depthmap. It shows as a small black rectangle if opening the menu from another scene which has other coordinates.
Another question would be how to hide 3D placed hotspots when menu is opened so nothing overlaps.
Thanks and kind regards,
loki
jeromebg
Professional
26
Saturday, April 24th 2021, 10:10pm
This plugin is not designed for what you want to achieve, sorry.
27
Thursday, May 13th 2021, 7:28am
trigger another action via menue button
Hello,
I recently bought the "VR Thumbnails Menu Plugin" and I am satisfied.
But I have the following problem:
There is a large white information board that you can open in my panorama. If the menu is then also opened, it looks ugly in the background because the white board is too large, too close and bright even through the overlay.
Is it possible to trigger another action when the menu button is clicked? Just like:vrmenu_onclick = "close_info-board ();"
I would be happy to have a solution for that.
Thanks and best regards,
Kolja
jeromebg
Professional
28
Thursday, May 13th 2021, 9:10am
Can you post the link of your tour ?
Normally all hotspots should be hidden when VR menu is opened.
29
Thursday, May 13th 2021, 3:03pm
thanks for the fast respond!
Here is the Link: (work in progress)
https://www.koljaraschke.com/360/Staatsb…rk-in-progress/
Please click menu right top to choose VR Mode, and than click on the blue i on the "real" showcase in the pano, you see left in front.
If I set the hotspot/info board to zorder = 1, the info board appears behind the vrmenu overlay. If I set zorder more than 1 it is like you see now in the pano. But I have some zorder arrangement and need more range :)
Anyway I like to hide the info board totally in the background while open the menu, because it is more elegant and nicer to see the room in the background behind overlay.
(It will happen, that visitors open the info board first, and than directly clicking the menu button, while info board is open.)
The hotspot ist just a simple image hotspot (here with zorder=2 like you see online right now)
<hotspot name="info-image-board" type="image" keep="true"
url="skin/info-image-board.png"
width="405" height="685"
enabled="true" capture="false" zorder="2" alpha="0" zoom="true"
 flying="0" depth="off" handcursor="false" distorted="true" />
Thanks!
Kolja
jeromebg
Professional
30
Friday, May 14th 2021, 11:23am
Send me a mail with the one you used when bought the plugin, I have a fix for you ;)
31
Tuesday, November 8th 2022, 9:08pm
Hello!
Jeromebg, thank you for your awesome plugin.
Is it possible to add to the floating menu other items?
In my vr-tours I usually overwrite the default krpano floating menu by adding my items (like playing music or opening the information box) - like this - https://scanvi.ru/stream/2022/solov/
I would like to have the ability to run from the floating menu (default or yours) - my items and vr-menu both.
So I suppose there are two ways to do this:
1 Having a special section to add to your floating menu new items.
or
2 Having the ability to disable your floating menu, enable default, and know an action to run vr-menu just to start in from any place.
I suppose the 2nd way is more flexible for creators and I like it much.
jeromebg
Professional
32
Wednesday, November 9th 2022, 4:12pm
You could "hide" my VR menu icon overriding it's url for example, add after the plugin include
<hotspot name="vr_menu_home" url=""/>
to open the vr menu call the action show_vrmenu
Best
33
Wednesday, March 22nd 2023, 8:10pm
depth map
What to do if in a tour with a depth map, my menu is constantly at zero coordinates
