San7
Professional
  • "San7" started this thread
Occupation: coding in krpano
41
Tuesday, October 5th 2021, 5:30pm
This is a demo version on google disk, I hope there will be no problems *smile*
https://drive.google.com/file/d/1XFjpCtN…iew?usp=sharing
loki
Trainee
42
Thursday, November 18th 2021, 5:13pm
I removed the urls for googlemaps.js and bingmaps.js from vtourskin.xml action "skin_startup" and removed the js files from the plugin folder. It seems there is no problems with this. Do you think there could be any problems or is it safe to do so? I don't want my tour to load the google api, only using floorplan plugin.
Thanks for your input.
Best,
Max
San7
Professional
43
Thursday, November 18th 2021, 5:19pm
the googlemaps.js and bingmaps.js plugins have nothing to do with the floor plans plugin. You can delete them.
loki
Trainee
44
Thursday, November 18th 2021, 8:09pm
Thanks for quickly reassuring *thumbup*
loki
Trainee
45
Thursday, November 25th 2021, 6:54pm
Hi, use the native krpano tool to align north.
Disable in the plugin "KEEPVIEW" and set in the tour loadscene_flags = "KEEPVIEW"
You will no longer need to align the radars in the plug-in, just initially correct the compass. If you set the correct north everywhere, the radar will automatically show correctly and should work normally in vr mode
Hey Alex,
before 1.20.10 I created my tour, aligned all scenes using floorplan plugin, positioned all hotspots, now stumbling over this vr keepview problem.
Is there a way to fix it without prealigning all scenes and hotspots from scratch?
//edit: The Keepview settings work in simulated-browser-webvr mode by the way.
Thanks and best,
Max
San7
Professional
46
Thursday, November 25th 2021, 8:03pm
Hello, fix the alignment in the Krpano editor and set the prealign=true in the hotspots
loki
Trainee
47
Thursday, November 25th 2021, 8:56pm
Ahhhhhh! Thanks for the fast reply. Wasn't even aware of hotspot prealign="true" *whistling* *thumbsup*
San7
Professional
48
Friday, March 18th 2022, 10:02am
Hi all! This is a small update of Floor Plans v1.47
  • When switching plans, moving the plan with the mouse was not limited. fixed.
  • When navigating by points in the plan, the plan could move beyond the window dimensions. Fixed
Download demo version
San7
Professional
49
Wednesday, January 18th 2023, 6:27pm
Hello!
Small update Creating Floor Plans v1.48 *smile*
Now it has become easier to put points on the plan, especially with large volumes
Download link use your pin_flpl.xml !
panoyun
50
Thursday, January 19th 2023, 4:38am
*thumbsup* *thumbsup* *thumbsup*
San7
Professional
51
Monday, May 29th 2023, 8:25am
This is a test version. The plugin has been completely redesigned and works with krpano version from 1.21 I have not made a description yet, but I recorded an example on YouTube .
You can download demo plugin. This is a fully working version, only there is an inscription - demo
Now you do not need to enter a password. But the plugin is tied to your krpano license
a window with a plan is a frame in which a flat pano with a plan opens.
52
Saturday, June 3rd 2023, 7:27am
Great! *thumbsup*
Is it possible to use this plugin in depthmaps too?
San7
Professional
53
Saturday, June 3rd 2023, 8:28am
Hello! Thank you!
Yes, you can use it in the 3d model, only the click on the points will need to be reassigned to the code that you use to navigate in the tour with a depth map.
Here is my example
