Benutzerinformationen überspringen
Beruf: Virtual tours, Krpano coding, Graphic Design, Photographer, Panographer
Beruf: krpano freelancer || creating ideas & coding them || krpano developer
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Konstantine« (15. März 2018, 13:02)
Luis
Hi Luis,
great plugin! In a Vtour it possible to use as text not the "tag" but the linkedscene title? As the normal "skin_hotspotstyle" does?
Best,
Marc
Hi Luis,
Best,
Marc
Hi Luis,
Best,
Marc
Hi Luis,
Best,
Marc
push :)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Richard777« (25. April 2020, 22:00)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »datofz« (20. Januar 2021, 22:53)
The developer has amended this plugin to fix the above.In previous versions when you clicked on the Main Circle Hotspot on mobile devices it would rotate the pano to look at the hotspot and animate the activated circle hotspot. This hotspot would remain on screen until an "onclick2" call. This does not seem to work any more. With the latest version of krpano the activated circle hotspot only remains on screen when you are looking directly at it. I hope this makes sense.
Damien. plugin is updated now at krpanoOn my last dev (krpano 1.20.9), hotspots works on desktop but not on mobile (firefox like chrome).
on mobile click on hotspaot adjet the fov but that's all. impossible to loadscene.
Have you some idea ?
Damien
I have modify the plugin. So now you can go to the linked scene and use the linkedscene_lookat info to lookat.I notice with latest version of krpano with this plugin that linkedscene_lookat doesn't work. It always reverts to the scene's view. Hoping there's a resolution to this.
Source code |
1 |
onclick2="loadscene(get(name),null,MERGE,get(skin_settings.loadscene_blend));skin_updatescroll();" |
