michel
Professional
  • "michel" started this thread
Occupation: TV
Friday, November 6th 2009, 4:31am
Border attribute for <area> node
Is there an attribute to set a border to the area? I have tried with <area border="2" ...> but it seems border does not exist.
Also, trying to answer a thread from machart (new approach for widescreen presentation) I have made a working border to the area in this way:
	<!-- border  -->
	<plugin name="border_top"    url="border_x2.png" enabled="false" align="lefttop"    edge="lefttop"	/>
	<plugin name="border_bottom" url="border_x2.png" enabled="false" align="leftbottom" edge="leftbottom" />
	<plugin name="border_left"   url="border_x2.png" enabled="false" align="lefttop"    edge="lefttop"   />
	<plugin name="border_right"  url="border_x2.png" enabled="false" align="righttop"   edge="righttop"  />
	<!-- action to set the border of the area -->
	<action name="set_border">
		set(plugin[border_top].width,get(area.width));
		set(plugin[border_bottom].width,get(area.width));
		set(plugin[border_left].height,get(area.height));
		set(plugin[border_right].height,get(area.height));
Here an example working with this code: http://andorra360.com/test/ForumKrpano/machart/area.html
It is ok.
But, before using this working border code, I was using the same code with the plugins aligned in a different way... Like this:
	<!-- border  -->
	<plugin name="border_top"    url="border_x2.png" enabled="false" align="top"	edge="top"    />
	<plugin name="border_bottom" url="border_x2.png" enabled="false" align="bottom" edge="bottom" />
	<plugin name="border_left"   url="border_x2.png" enabled="false" align="left"   edge="left"   />
	<plugin name="border_right"  url="border_x2.png" enabled="false" align="right"  edge="right"  />
Here an example working with this code: http://andorra360.com/test/ForumKrpano/m…er_problem.html
Here, the sides of the border have a strange behaviour... if you try to resize the browser, when the area.width or area.height are odd, the corresponding border does not match the entire area.width or area.height. *wacko*
Is it a bug?
Anyway, I like the new area feature... It gives a lot of new possibility. Great *thumbup*
Thank you Klaus.
SAlut.
Sunday, November 8th 2009, 7:16pm
no, there is no border attribute at the moment,
and I'm not sure if making one makes sense, because there must be also a lot of other settings, e.g. borderwidth, color, and so on...
making a border by images or maybe by a dedicated "border" plugin should be better and more universal,
great example btw.
Is it a bug?
yes and no
to avoid "jumpy" positions when switching between different flashplayer quality settings (like when switching between movequality LOW and stillquality HIGH), internally the position calculation rounds some values, this leads to this effect,
it can be solved by using not centered align positions (left,top,bottom,right,center) like you already did,
or by setting a currently undocumented attribute - accuracy="1" - then the width in the position calculated will not be rounded and it will work correct,
something other too - when using - width="100%" and height="100%" - the border sizes must not be updated manually, then they will scale automatically
e.g.
<plugin name="border_top" url="border_x2.png" enabled="false" align="top" width="100%" accuracy="1" />
<plugin name="border_bottom" url="border_x2.png" enabled="false" align="bottom" width="100%" accuracy="1" />
<plugin name="border_left" url="border_x2.png" enabled="false" align="left" height="100%" accuracy="1" />
<plugin name="border_right" url="border_x2.png" enabled="false" align="right" height="100%" accuracy="1" />
Sage
Sunday, November 8th 2009, 8:19pm
is it possible to put the google maps map or the control buttons outside the stage with this??
so , in the black area?
Cheers
Tuur *thumbsup*
ps nice but difficult code michel... i try to understand... *huh*
http://www.virtualtuur.com
Skype:studiotuur
michel
Professional
Occupation: TV
Sunday, November 8th 2009, 8:48pm
Hi KLAUS,
More easy now. I have posted an example here: How to reset the <area> to the default ?
Thank you KLAUS *thumbup*
Hi Tuur,
all plugins will also be automatically aligned inside this area,
but to aligned a plugin/image outside of it, set the "parent" attribute
of this plugin to "STAGE" (but note some plugins, like the googlemaps one will require an update to get this working)
Quoted from "Tuur"
Not so difficult ;-) . Look at the link above to see an example code. (there is some comments in the code to explain *smile* )
SAlut.
