2) drop needed panos onto "Make Object" and that was it.
However I've just done so and got an error:
Quote
ERROR: unable to load html template: .../templates/html/swfkrpano.html
A quick search revealed that 1.16.9 has this template together with "swfkrpano.js" in the tempaltes/html" folder.
So I copy-pasted the html template, took any 1.17 .js file, renamed it to "swfkrpano.js" and then put them into "tempaltes/html" of 1.17.pr2. And then all worked. However, I'm not sure if this the right way to do and whether I should adjust template paths inside "multiframe.config" itself.
