Hello,
I'm using a imagemap example and I want to adapting open map to size on mobile/tablet devices. And of course needed resizing when change orientation of the device from landscape to portrait mode.
I spent a lot of time to do the "smart map", but for today my attempts failed!
To my understanding it was very difficult, I'm sure we need more complex mathematical calculations.
How? Any advise please...
Thank you!
Cheers,
Ars
imagemap - how to resizing and adapting?
Hi!
take a look at this
http://sudarchikov.com/shared/automapnew/tour_html5.html
http://sudarchikov.com/shared/automapnew/tour_swf.htmlDraggable/scrollable multilevel map
Perhaps it can be usefull in such caseRegards
Andrey -
It is important to keep aspect ratio of the image and same time keep screen aspects in consideration. This is something I did in the past using examples provided by Klaus:
http://webonjee.com/radna-mapa/ant…_map/index.html
Code you can see here: Code
Complete working example package you can download: Here
Enjoy the rest of the day ;)
regards
Umalo -
Thank you guys for your responses!
Said before, but just noticed that my answer was not published!
Write again)Umalo, yes! exactly! That thing that I need for my simple needs!
Really supermap
I tried play with settings, works fine!
Thank you very much!
=========Sudarchikov Andrey, hi!
is this plugin?: https://krpano.com/plugins/userplugins/automap/#top
Nice solution! Maybe I'm will try use in future projects with large plans/maps!
Thank you!
BTW, it's your plugin too? Map with mode of full size area, very usable:
http://spacer.gminakwidzyn.pl/
Display More
regards
UmaloAny chance that you can re-upload the code please?
Found old code and re-uploaded. Try now.
regards
Umalo
