how to call a Javascript plugin method from outside?
  • I have a Javascript plugin for the HTML5 viewer. I need to call its methods from outside krpano. What's the right way to do it?
    In my plugin I do:
    local.registerplugin = function (krpanointerface, pluginpath, pluginobject) {
    plugin.attachEvents = attachEvents;
    function attachEvents() {alert('attached');}
    then I've tried calling:
    krpano.call("attachEvents();");
    and
    krpano.call("plugin[myplugin]attachEvents");
    but notghin happens.
    here you need to use 'pluginobject' to access the krpano plugin object - and the name of the function at the plugin object need to lowercase (!):
    and here a dot (.) and brackets are missing:
    Zitat
    krpano.call("plugin[myplugin].attachEvents()");
  • My fault, I meant pluginobject in my first code snippet.
    Calling with
    didn't work wither.
    I've completely rearranged my plugin. Now I instantiate it by myself, passing the krpano object to it . Far more flexible and easy to manage ;)
    Thanks anyway.
  • Make sure the function name was written here in lower case:
    pluginobject.attachevents = attachEvents;
    To provide case-insensitive access, krpano internally converts all actions to lower case, so the function name also need to be lower case to be call-able by krpano.
  • Thanks for the help, but it doesn't work with lower case neither.
    Should I define some more parameter when I define the plugin?
    <plugin name="myplugin"	url="myplugin.js"  parent=""	preload="true"	x="0" y="0"	visible="true"	keep="true"/>
    I use the krpano obtained from "krpanoSWFObject"
    krpano = document.getElementById('krpanoSWFObject');krpano.call("plugin[myplugin].attachevents()");
    PS: does the HTML5 viewer use SWF under the cover?
