Hi
How to build shooting at an altitude meters above ground level photos?
Use a stool or ladder to lift the car?
However, using a handheld camera movement panohead.
Of course I know the remote control helicopter can do, but I wanted a proper solution.
I was shooting from a tripod to a height of 1 m above the river water, and I've been shooting. Juice Camping.
Easy Solution for shooting with a tripod height is 3 meters?
Nodal ninja pole
Hi, Samadi!
A moment will come when I will buy myself the Pole Nodal Ninja, but at the moment I use regular studio stand (cheap price ~$60)!
That allows take pictures with height up to 4 meters, there are stands and up, but then they are much heavier (
I'm attaching the head NN4+5dmII+Fisheye without rotator, rotating manually using the lower leg section of stand.
And get result like this:
https://dl.dropboxusercontent.com/u/735173/poltava/up360/index.html
Could you provide some more infos, Arsdezi? What studio stand do you use and how do you trigger the camera up there?
BR
Nupsi -
hello
poltava |saki_Resort was nice photography and I see that above link.
see this links for pole:
vimeo.com/3238252
shop.nodalninja.com/carbon-fiber-poles-all-1/thanks
samadi
http://www.mypano360.ir -
BR
Nupsi
Hi, Nupsi!
See pic in attachment(I do not want to wake up my family, photographed only the stand)
My DIY solution is very simple and cheap)- one studio light stand, made in China - $65;
- few the metal vent hose clamps -$3;
- thin steel safety cable -complete with two spring catch and hook-up slot(DIY), because I do not trust the Chinese head stands -$3;
- sticker with gradation of steps rotation - $0.1;
- radio flash/camera trigger Yongnuo RF-603 for trigger camera - $30-40
... and my Nodal Ninja 4 mounting without rotator.
Now I want buy Pole Rotator 60(or 45) degree stops (http://shop.nodalninja.com/pole-rotator-6…ee-stops-f7118/) for mounting fix on base and for turn column of stand using a DIY tube adapter ;)
And of course you can use wireless controller like camranger or similar for liveview mode and control all general parameters of your camera! -
Hey Arsdezi,
and thanks a lot for taking the picture and for the infos
I´m a huge DIY-fan and your solution looks a lot more stable than the fiber poles from NodalNinja and a lot cheaper too
BR
Nupsi -
Have a look at these.
Adapter (Standard 1/4 inch camera screw or 3/8 camera screw) Forget the resting plate
Paint Roller Pole Will hold a NN4 plus you can also add a cable to secure it as a backup
Wireless Remote I use this for everything and would order another if it ever packs up. 100m range.
