Hi, I am trying to deploy the Bing Maps as in the examples provided in the download - so aiming to have the bing map in a small box in the lower left hand corner. Ok that works fine.
Now I have for example 200 panos which all have lat/lng attributes and I want them to show as markers in the Bing Map and when one is selected the marker changes colour so you now it is active and this should happen even if I select a pano from a marker or click on a thumbnail or move to a new pano, the map should move to show the new location of the active marker. Basically for any selected pano I want the user to have a "you are here" reference guide.
I had this working fine when I had Tourweaver but now I have a better friend in KRpano and I want to try and do the same thing.
I am sure it can be done :)
