I made Window like the rearview mirror.
These will move in synchronization.
http://chiiden.com/panorama/2014/reverse-sync(room)/
↓ This is a fish-eye version.
Great!
Haha
Really nice!
Love it.
Share or buy?
This was made by improving the krpano template.
Please refer to the following.
krpano→examples→javascript-interface→js-sync→syncscreen.html
1.syncscreen.html
<div id="viewersDiv" style="position:absolute; left:0; top:0; width:100%; height:100%;"> <div id="krpanoLeftDiv" style="position:absolute; left:0%; top:0; width:100%; height:100%;"></div><div id="krpanoRightDiv" style="position:absolute; left:65%; top:5%; width:30%; height:25%;"></div> </div>
// sync viewer movement function sync_1to2() { var krpano1 = document.getElementById("krpanoLeftViewer"); var krpano2 = document.getElementById("krpanoRightViewer");
krpano2.set("syncother", false); krpano2.set("view.hlookat", krpano1.get("c-hlookat")); krpano2.set("view.vlookat", krpano1.get("c-vlookat")); krpano2.set("view.fov", krpano1.get("view.fov")); }
function sync_2to1() { var krpano1 = document.getElementById("krpanoLeftViewer"); var krpano2 = document.getElementById("krpanoRightViewer");
krpano1.set("syncother", false); krpano1.set("view.hlookat", krpano2.get("c-hlookat")); krpano1.set("view.vlookat", krpano2.get("c-vlookat")); krpano1.set("view.fov", krpano2.get("view.fov")); }
2.pano1.xml
<krpano syncother="true" onstart="ifnot(haveexternalinterface, error('ExternalInterface (Javascript Interface) not avaiable![br][br]Check your Flashplayer security settings:[br][br] http://krpano.com/docu/localusage/'));">
<image> <cube url="../../xml-usage/slider-blend-cubes/pano1_%s.jpg" /> </image> <contextmenu fullscreen="false"> <item name="kr" caption="KRPANO" /> <item name="fs" caption="Toggle Fullscreen" onclick="js( requestfullscreen() );" /> </contextmenu> <events onmousedown="set(syncother,true); events.onviewchange();" onmousewheel="events.onmousedown();" onviewchange="cv(); if(syncother, js( sync_1to2() ) );" />
<action name="cv"> add(c-hlookat,get(view.hlookat),180); mul(c-vlookat,get(view.vlookat),-1); </action></krpano>
3.pano2
<image> <cube url="../../xml-usage/slider-blend-cubes/pano1_%s.jpg" /> </image> <contextmenu fullscreen="false"> <item name="kr" caption="KRPANO" /> <item name="fs" caption="Toggle Fullscreen" onclick="js( requestfullscreen() );" /> </contextmenu> <events onmousedown="set(syncother,true); events.onviewchange();" onmousewheel="events.onmousedown();" onviewchange="cv(); if(syncother, js( sync_2to1() ) );" />
I thought already that was the way.. sort of.
How did you get the round perspective?
Thanks!
in pano1.xml and pano.2.xml, I have to convert the view.
Please look at <action mane="cv">.
view.hlookat +180 → c-hlookat,
view.vlookat ×(-1) → c-vlookat .
These values are specified in the js of html file.
You see?
ye si see that and understand but the second example is sort of mirrorball perspective.
How to make that?
It will be possible by fisheye view.
fisheye="1" fisheyefovlink="1" stereographic="false"
<view hlookat="0" vlookat="0" fov="180" fovtype="MFOV" maxpixelzoom="1.0" fovmin="20" fovmax="180" fisheye="1" fisheyefovlink="1" stereographic="false" limitview="auto" />
However, seems to have some problems.
Great! Especially the fisheye version!
What do you mean with 'However, seems to have some problems' ?
For me it looks fine...
Thank you for watching.
Problem that I feel is as follows.
1.Immediately after it is loaded, there is a part resolution is not sufficient.
After scaling, it is normally displayed.
2.Immediately after loading, + - button does not work.
after scaling in sift and ctrl button, you can function.
3.Have put a description of the drag cursor, but the hand of the icon is not set.
If you can examine , I will send the data set.
Thank you!
Yasushi Kumon
Very nice and creative. I love it....
Klaus,
On the first place congratulations with this fantastic software program Krpano, Klaus youre the greatest master of the universe.
I have a issue:
Pano_b gives a blurred screen, but after a few clicks of zooming then disappears blurred screen.
See link: http://bit.ly/1DyoqGd
Is this a bug?
Yasushi,
Great a splendid example of fisheye possibilities.
I try to realize this also but I cannot get it working, can you help me?
Best Regards,
Wilsan
When tested on another computer with Internet Explorer 11.0 shows that the blurry pano changed to another position left, right, up enc.......
Possible a loading problem indicates a bug?
Klaus, you can check this, thank you, for your feedback.
Best Regards,
Wilsan
Yes, that's already on my check-list.
I will post here once I know more.
Thanks Klaus, Great.
Wilsan
I tried the new version.
It is displayed correctly, it is working.
http://chiiden.com/panorama/2014/…m)/fisheye.html
(This is the same URL as the old version.)
I am very grateful.
Thank you!
Yasushi Kumon
Thank you klaus,
I have applied the new version and it works correctly.
http://bit.ly/1HTdAda
Thank you very much.
Wilsan
can you do the same with two fisheye video?
thanks
I made a video sample.
