have a look:
https://krpano.com/forum/wbb/inde…ad&threadID=259
and I'll try to add a better way to do this in the next versions
have a look:
Quotein the most cases hlookat will not be exact -179, even more "-179.464564" for example
to check it you need to use "view.hlookat"
The view angle would be whatever is set by the initial onstart action, so perhaps it might be an absolute value? Hmm...
I've just realised that I may be shooting myself in the foot with the code. Does it matter that I've left the version element in?
krpano version="1.0.7" onstart="action(startview); delayedcall(8, action(rectview););"
k
if you set to "-179" at the start, then you can check for it, thats right
but note - use "view.hlookat",
the "version" should be set to "1.0.7" or a higher value or removed,
if it's "1.0.6" or lower, the set/get could behave a little bit different
Thanks Klaus - the other thread looks rather interesting too!
But it feels like I'm going backwards now: if I use the options plugin it now just tells me "wrong krpano version". Does that not work with this beta? If this sort of thing is an issue would it be possible to download a complete set of everything each time?
(This is something that I've found to be rather confusing from the start - what version is what, what extras go with which krpano version, and so on. Version control is a bit of a nightmare! I seem to remember finding that some of the examples wouldn't work with the version of krpano that they shipped with...)
k
QuoteBut it feels like I'm going backwards now: if I use the options plugin it now just tells me "wrong krpano version". Does that not work with this beta? If this sort of thing is an issue would it be possible to download a complete set of everything each time?
Hi, just make sure that the krpano.swf and the plugin swf files are from the same version/download package,
if you use the krpano.swf from the 1.0.8 beta 5, you also need to use the plugins from this download
to check the current krpano version - press the 'O' key in the viewer, this opens a log where the
version is displayed in the first line.
Quoteif you use the krpano.swf from the 1.0.8 beta 5, you also need to use the plugins from this download
Thanks Klaus - my face is red, but I'm very happy. I'm still learning! (Learning to look properly, for one thing... )
k
when using a cylindrical preview image... what is the correct xml format?
I've tried a couple different variations and keep ending up with a preview image that looks spherical with a lot of black space on the top and bottom.
Thanks.
partial previews are not working in beta 5,
the beta6 will fix it,
this partial image has only a horizontal field of view of 45 degree,
that means the left and right edges are not connected,when the horizontal field of view covers a range of 360 degree then it will be "loop"
Can one program it with this 1.0.8 version to make it loop? As far as I can tell I have the pano stitched so it should be able to loop.
Hi, yes, just remove the hfov="..." setting or set it to hfov="360",
then it will loop horizontally
the next beta version is ready - 1.0.8 beta 6
now - together with a new version of the krpano tools:
download it here:
https://krpano.com/download/beta/
EDIT - Updates/Bugfixes:
2009-02-25:
- fix in the krpano.swf for the plugin align bug
- fix in the kmakemultires tool for partial panoramas
- added a "snowing" version of krpano
2009-02-26:
- qtvr error message bugfix
2009-02-27:
- added "Pannini Projection"
- crash bugfix in ktransform
- added a very first release of the kcube2sphere tool
2009-03-02:
- kprotect bugfix - xml embedding without domain lock works now
- soundinterface plugin - added check for the possibility to play sound
- bugfix domain/FQDN checking - a dot(.) at the end of the domain is now allowed
- added CUBE to SPHERE droplet
here is a list of the changes compared to beta 5:
(for the full list of changes have a look at the "releasenotes-1.0.8-beta6.txt" file)
VIEWER:
changes:
- partial preview images are possible now
- autodetection of preview image type when no "type" is defined
- allow embedding of license/xml into the swf (kprotect tool)
- allow creating of standalone flash projector files (kprotect tool)
- automatic download retry on server busy errors (only on HTTP return codes 503 and 504)
- optimized krpano.swf loading
- reduced swf filesize
- some small multiresolution rendering enhances/bugfixes
new attributes:
- <krpano> - showerrors="false" - to disable the opening of the log on errors
- <events> - onpreviewcomplete, onloadcomplete (experimental at the moment, warning - can interfere with "onstart")
- <plugin>/<hotspot> - ox/oy - addtional x/y offset, % values can be used and they are relative to the own size
- <plugin>/<hotspot> - rotate - rotation in degrees
- <plugin></hotspot> - enabled - enable/disable all plugins or hotspots globally - "hotspot.enabled", "plugin.enabled"
new/changed actions:
- copy(dst,src); - copy variable value
- tween() - can now be used also with percents(%) values
- stoptween(var1,var2,var3,...); - stop one or more tweens
- trace(a,b,c,...); - traces variables or any text
- inc/dec(var,value*,max/min/saturation-value*); - increase/decrease values (with saturation)
bugfixes:
- pop() action caused skipping of the following action
- a javascript call to a not existing function show a error instead of crashing/stopping the actions queue
- checking for full 360x180 panos (aspect 2:1) - accurrey reduced, 1 pixel difference allowed
- hotspot visible toggle - position recalcution on becoming visible
PLUGINS:
googlemaps:
- onhover was also done on visible="false"
- resetspots() (main bugfix done in viewer)
- debug traces removed
textfield:
- "wordwarp" attribute (default="true")
combobox:
- labels now have correct case again
soundinterface:
- correct error message when a file could be found
TOOLS:
a new GUI tool - kprotect - krpano Protect Tool (not completely finished yet!)
it allows to:
- create protected panos for end users/customers and to protect your work
- create standalone viewers for windows and mac (.exe/.app files)
- embed and encrypt the xml direct into the pano
- embed the license
- limit the panorama to specific domains
- set an expire date for the panorama
- create "branding free" panoramas (additional license required!)
- final version will also allow to embed or encrypt any kind of additional file (xml, plugins, images, panos, ...)
kmakemultires:
- updated for krpano 1.0.8 usage
- added support for partial/cylinder/flat panoramas
- new droplets
all tools/droplets:
- fixed problems with paths that contain blanks and special characters
Looks great Klaus!
I have an unlimited domain license. Can you explain the "branding free" additional license? I don't see anything on your purchase page.
Dave
Looks great Klaus!
Dave
Just tried kprotect.exe , everything worked nicely in the generated EXE file except for the combobox and soundinterface plugins. Even though the path was correct, krpano wasn't able to find the 2 plugins. Maybe a bug ?
Hi Klaus!
Krpano Protect Tool - It's very necessary thing!
We wait final release...
Thanks!
my oh my!!! what wonderful news!!! I can finally use krpano to deploy on clients sites! :D
also, Klaus, will we be getting the updated Google maps plug in by email (the paid one of course for those who paid :-P ) ?
Klaus, will we be getting the updated Google maps plug in by email (the paid one of course for those who paid)
I had the same question...
Or do we use the download link we had from when we purchased it originally ( if I can find it ) : )
I think it's in your new plugins update map.
You got the license API key so i think that should work..
Cheers
about the googlemaps plugin update - I'm currently preparing a system that always allows to download the newest versions,
but if you need it urgent - just write a short mail and I will sent it back to you
could be possible, I will check this
