something like this:
ZOOMBLEND(time, zoom, tweentype, direction)
where direction is angle 0-359. 0 is forward and identical to classic zoomblend
Hi!
there is set of blend styles
https://krpano.com/docu/actions/#loadpano.blend
so you can define which one is better for you, simple change it in loadscene action
you can detect what is the movement and set it dynamically as parameter
Hope it helps
Regards
Andrey
There is some misunderstand I think
there is no transitions like google street view, like matterport or like this:
https://www.youtube.com/watch?v=CQ-cwJ_UD6Q&feature=youtu.be
based on https://github.com/henryseg/spherical_image_editing
everithing that krpano have is "slide show" effect and do not support direction of the movement in the tours
Yep, you are right, krpano has no such effect
Theoretically such would be possible of course - but a 3d-geometry (or a depth-map) for the pano would be required. The question is where to get or how to build that geometry? A normal pano image alone doesn't contain/provide that information.
Klaus,make 3d model is easy for now,after shoot panorama,you can use contextcapture,this software can make photos convert into 3d model.Then use this model and panorama make "matterport effect",and another woderful case is geocv,here link: https://geocv.com/americancopper31c
Geocv use samsung s8 smartphone and a Structure Sensor make 3d model,but in reality,we don't need a Structure Sensor,just a phone is done.
And i make a indoor 3d model with my iphone 11,i'll send model and panorama to you for test,have a nice day!
What I don't like about Matterport is that it's a proprietary solution. The other point is that all the visits are the same and that only the prices are taken into account. The result is a red ocean for photographers who get started with this technology.
The other aspect is that the 360 ° real estate market is extremely weak in France and certainly in Europe.
For me the only way to add value to the virtual visit is to make enriched visits with multimedia. Tools like KR Pano and other non-proprietary systems are more flexible.
Personally it is essentially the Google Street View platform and the enrichment's on the Street View virtual tours that allow me to make a living.
If you want to know more you can visit my web site : https://visite360pro.com/
Some years ago I've looked into matterport, so I cant say my finding from back then still holds true, but back then at least I concluded it was a mere photogrammetric approach. Images are uploaded into the cloud, pairs are found, features are extracted, their relative movement to each other is determined and voila, you get the distance of each feature to the viewport.
hi You need to use this method to collect how to shoot
