my panorama vtour works on PC perfect But doesn't work on mobile........
I use version 1.18
I'm confused.................
I use version 1.18
vtour works on Desktop perfect But doesn't work on web and mobile........
my panorama vtour works on Desktop perfect But doesn't work on web and mobile........
I use version 1.18
Please post a link to your example.
panorama loads But
Hotspot, combo box, menu, skin,.......... doesn't work.
You're right there is an error into the javascript console on tour.js file with this url : http://www.info360.ir/uploads/flash/…html?html5=only
What's happen ?
Can you share a link ?
on which devices and browsers doesn't it work?
Btw - try to rename the dblclick.js - when an add-blocker add-on is installed, this file will be get blocked and cause an error.
