[Solved] make hotspot invisible in little planet works with Flash , not HTML5
    little problem again,
    when i add dynamically hotspots with addhotspot,
    and i want them invisible for little planet view,
    the following code not works in html5 but works in flash
    set(hotspot.visible, false);
    with normal hotspots (not by addhotspot)
    code works in flash and html5
    krp.119.pr2
    why ?
    thanks
    z
    Edited once, last by zadda (September 6, 2015 at 1:19 PM).
    the hotspot.visible, hotspot.alpha settings are currently Flash-only - see here:
    https://krpano.com/docu/html5/#supportedfunctionality
    In the Flash version all the hotspots are with an internal layer and these settings are controlling the visibility of that layer. The HTML5 used internally a different organization (due technical reasons) and therefore this is not directly supported there.
    here an action for hiding or showing all hotspots:
    <action name="set_all_hotspot_visible">
      for(set(i,0), i LT hotspot.count, inc(i), set(hotspot[get(i)].visible, %1) );
    To hide all hotspots call:
    set_all_hotspot_visible(false);
    and for showing them:
    set_all_hotspot_visible(true);
  • Thanks Klaus for replying
    but that not works *cry*
    not only my hotspot remain visible when entering little planet but the webVR hotspot target become visible when exiting ...
    and invisible when re-entering little planet, it mean your code is correct *thumbup* but it doesn't works on my hotspots.... *sad*
    my hotspots are added with addhotspot in an action like this :
    is there something to add ? *confused*
    z
    please show your full example - e.g. when do you add your hotspots? only once at startup?
    And about showing and hiding only specific hotspots - you could add a custom attribute to them and then check in the for loop for that.
