I’m having a heck of a time getting krpanotools makepano to “work” via Python scripting.
I’m performing this all under OS X 10.10.4, Python 2.7.6
My scripting “watches” a folder for new equis and process accordingly.
Two paths are set; One to the equi to be processed (originalPath) and one pointing to the destination directory (newPath)
I can create the new destination directory via:
os.makedirs(panoPath)
I can create cube faces via:
os.system(krpanotools + " sphere2cube cube " + originalPath + " " + newPath + ".jpg -config=convert.config")
And then create a preview-strip via:
os.system(krpanotools + " makepreview " + faces + " -cs")
I can then remove the original equi via:
os.remove(originalPath)
So, everything I just described fires off - no issue.
However, when it comes to creating the tiles, no go.
If I remove the sphere2cube, makepreview and os.remove steps and insert the code below in its place nothing happens except for the new directory creation; i.e. os.makedirs(panoPath).
Obviously this is pilot/coder error on my part and not a krpanotools error since I can seem to get cube faces and preview strips created.
I'm pretty sure that "paths" are not the issue since they seem to be working just fine when invoking sphere2cube( but I could be in error ).
I am using the krpanotools that came with the 1.19-pr3 version of KRPano.
I’m looking to produce just images and tile directory structure. No html, no xml.
ANY insight as to what I’m doing wrong would be very much appreciated!
CODE I’M TRYING TO UTILIZE:
My scripting for “makepano” is the following:
os.system(krpanotools + " makepano -config=multires.config tilepath=" + newPath + “the.tiles/[mres_c/]l%Al/%Av/l%Al[_c]_%Av_%Ah.jpg previewpath=" + newPath + “the.tiles/preview.jpg customimage[mobile].path=" + newPath + “the.tiles/mobile_%s.jpg " + originalPath)
My multires.config file contains:
# Multi-Resolution Panos
# Skin with Default Buttons
# Documentation: https://krpano.com/tools/kmakemultires/config?version=118
# krpano 1.18
# basic settings
panotype=autodetect
hfov=360
# output
flash=false
html5=false
# convert spherical/cylindrical to cubical
converttocube=true
converttocubelimit=360x45
# multiresolution settings
multires=true
tilesize=512
levels=auto
levelstep=2
maxsize=auto
maxcubesize=auto
leveldownload=auto
# preview pano settings
preview=true
graypreview=false
previewsmooth=25
# generate smaller mobile images
customimage[mobile].size=1024
customimage[mobile].imagesettings=jpegquality=85 jpegsubsamp=444 jpegoptimize=true
customimage[mobile].xml=<mobile>[NL][TAB]<cube url="[PATH]" />[NL]</mobile>
# xml output
xml=false
# html output/template
html=false
# compression settings (note - no jpegoptimize for extreme big panos, this could cause too much memory usage during building)
jpegquality=82
jpegsubsamp=422
jpegoptimize=false
