Klaus, is there a Chance to do html5 Sound Object this year?
HTML5 sound object
The year is very young so I think yes!
is there any solution because i need to buy this player if this bug is fixed
Do you have any plan to share the repository of soundinterface since it's free plugin?
Or, you may switch it to be opensource project.
what do you think? -
by now 2016 is.. lets say... middle-aged :)
is a new plugin still planned or in development ?
supporting volume for multiple audio sources?
2d / 3d stuff? -
2d / 3d stuff?These days, I've looked up and researched on html5 sound api.
Furthermore, I got to know that -probably- krpano is using Web Sound API - not Html5 <audio> tag.
Web Sound API is not cover all features what we are expected so far.
And even more, IOS system limit the sound functionalities.
Since that, i think 3d stuff is not in the boundary of klaus.
For information,
My project team decided not to use flash anymore.For only html5 sound, I got a alternative of Sound Interface supported Krpano.
If you see this post to lookup some more sound interface event like - play, stop, pause, end, and so on.. - Check this project.
https://github.com/goldfire/howler.js/I solved the problem I faced with howler.js.
This has sound played without additional screen touch - I think it Does require 'touch', but some other moment when Sound Interface does. -
thanks,
pavel and piotr's plugin (https://krpano.com/plugins/userplugins/html5vraudio/#top)
is probably based on this...i just wanted to know if klaus is doing an own plugin update
or if he dropped the plan
