Hi, Are the tours Facebook compatible? If so can you show me an embeded tour on a facebook page so that I can be sure? I am concerned that the logo element might take over the screen too much.
I look forward to hearing from you.
Hi, are floor plans now part of Tour Builder as I do not see them mentioned on the krpanostore website or see any examples? Also are there more templates apart from Spartacus?
Hi
1. Can I change the button to go to the panorama?
- I want to change the icon. How do I open vtourskin?
It is encrypted.
In the what template? Basically the panorama icon you can change in the settings.xml file (skin/templates/settings.xml)
2. Can I disable the Contextmenu?
No.
Can I sell my production for commercial use?
Yes. You can sell all your projects builds by Virtual Tour Builder but not Virtual Tour Builder itself.
Best regards
Piotr
Hello,
It's a good idea to add some sub-templates (to all templates) for Facebook embedding. A such a template must be simple and clear. The problem is that everyone would like it to look different and that is not possible.You can send me some suggestions as you like and I will consider them.
http://www.krpanostore.com/examples/vt-bu…lans/apartment/
http://www.krpanostore.com/examples/vt-bu…rplans/bunkers/
http://www.krpanostore.com/examples/vt-bu…ns/underground/
http://www.krpanostore.com/examples/vt-bu…oorplans/wspia/
The conceptual work on new templates is under way.
Best regards
Piotr
https://krpano.com/plugins/userplugins/htmlpage-plus/
works well under krpano fullscreen mode.responsive layout.
Thanks but what does your plugin have in common with Virtual Tour Builder
Best regards
Piotr
Hi Piotr, Many clients tell me that in VR mode they tend to lose orientation as to where they are in the building. I just wondered if it was worth exploring being able to have a floor plan displayed may be at the nadir point or at the bottom of the screen in VR mode so that you could always see where you are within a building/floor?
This is an interesting concept
I think about how it could be done. Thank you for the interesting suggestion.
Best regards
Piotr
Thanks Piotr :)
Hi Pior,
great work, I like VT Builder a lot!
Is there a manual how the settings.xml work?
As by the attached print screen, I would like to hide the buttons/symbols 1) and 2) and to define an initial location with coordinates for the (+) plus button 3).
and is there a possibility to disable the preview when clicking on a POI?
Is there any solution for this?
Thanks for your support.
Christoph
Hi
Thank you
Each template has a different settings.xml file. Targeting is determined by variable name. You can experiment.
These buttons can not be removed without an errors in the console - but they can be hidden. Try this code:
<style name="navi_bg" maskchildren="true" />
<style name="navi_btn_show_info" oy="-50"/>
<style name="navi_btn_show_history" oy="-50"/>
<style name="navi_btn_show_favorite" oy="-50"/>
<style name="header_favorite_ico" ox="-100" />
Paste it in the tour.xml file below a '<include url="skin/vtourskin.xml" if="singlepano != 0"/>' line
The position of this button can be defined in this style.
Try this code:
Best regards
Piotr
p.s. Of course, these proposals only cover the Umbrella themplate.
Hi Piotr,
The VT builder is proving to be extremely helpful, a little while ago i inquired about using the stickers function for lets say changing furniture items in a room.
Please could you offer a solution to displaying a category item on start and in a certain position? then when selecting an item from the same category, it open in same position?
Many thanks
Best regards
Piotr
Hi Piotr, I had another client ask about this yesterday. Any thoughts as to its possibility?
Kind regards.
Pete
Hi Piotr,
Im really enjoying using the stickers module and have a few questions i hope you can answer.
1. After ive added the stickers to my tour, the invite or open edited tour in new window buttons do not work? i get the following error message
FATAL ERROR: skin/stickers/911378110479519.xml - loading failed! (403)
2. When i view the my finished tour on my mobile only one sticker remains open at a time?
is this a memory issue? or can i configure this in the code? (Im using Spartacus template)
Many thanks
Alles anzeigenHi Piotr,
is this a memory issue? or can i configure this in the code? (Im using Spartacus template)Many thanks
You may need to change the directory access permissions on the server: ROOT/skin/stickers/
Send me a link to the tests
Piotr
thanks Piotr,
I see some problems with the server. Check your consoles and contact the server administrator.
There is a lock php file that generates the necessary xml file with sticker data.
It's a simple php file that takes POST data.
Piotr
Many thanks Piotr, I will contact my administrator.
Once we have corrected this issue, will this also resolve the stickers in mobile mode being limit to one. currently when i add the second the first disappers?
thanks
Hello,
There is a NEW version of the Virtual Tour Builder (4.0.0). Besides the code fixes in the current version you can create your own language interface for the back-end.
How can this be done?
1. add your own phrase in the file: 'skin/edit/xmls/lang.xml'
2. set a new value in the 'lang' variable: <krpano lang="en"> or <krpano lang="de"> or <krpano lang="fr"> ...
Link to the latest version was sent to all customers.
Kind regards
Piotr
Hello
I can change the hotspot color ?
the hotspots can be animated ?
Regards Dina
