Hi Piotr,
You were absolutely correct, the issue was as indicated by you
Zitata scene.count != pano.count
I've found the missing scene and fixed the error.
Thank you so much for your help. I've just learned a lot.
Christoph
Hi Piotr,
Christoph
Hello Piotr,
Can you advise if possible to add side menu or update menu and logo template easily with VT Builder?
ideally i would like something that looks like the attached.
many thanks
Hi Piotr,
Just a few questions about default Template (I think it's Umbrella):
• Is it possible to use animated hotspots? I really need them to point to active POI that are Livepano Flying objects.
• In VR mode, all ambient sounds are visible! It's confusing and totally useless for viewer since sounds are already playing...
• How to set categories open on load?
• How to set navigation panel closed on load?
Thank you very much.
What type of animation?
Zitat• In VR mode, all ambient sounds are visible! It's confusing and totally useless for viewer since sounds are already playing...
I will fix it and I will make an update.
I will add new settings in settings.xml to the next version of the template, which will control it.
Today will be an update.
Kind regards
Piotr
Hi
Alles anzeigenHello Piotr,
many thanks
This requires a new template. You can not just add this to the existing templates.
Kind regards
Piotr
Hi
There is a new version (v1.4) Umbrella template for Virtual Tour Builder .
news:
1. FIX bug with ambient audio hotspots in the VR mode - it's not showing now
thanx kagool for bug raport
2. new settings in the settings.xml file:
open_panoindex_onstart BOOL - open the panoindex for the start of the project - false is default
hide_navipanel_onstart BOOL hide the navigation panel for the start of the project - false is default
poi_to_pano_style - popup to new scene style (normal or circle) - 'normal' is default
You can download a new version from here:
https://www.krpanostore.com/download/umbrella-template.html
kind regards
Piotr
Thank you piotr!
works perfectly!
Hi Piotr,
Thanks for the update. It works like a charm but I have some new issues.
1 - Active category is not underlined as before.
2 - VR POI text are now hard to read due to the glow effect.
3 - Central plus button (toggle open menu) is vertically lower and hidden by categories if you start with them opened.
I apologize if I'm bother you.
Keep the good work!
Thanks.
Hi
This is fixed.
I did that you can control the height of this button yourself. There is a new property in settings.xml: vertical_y_bottom_menu_open_ico
You can change this if you want.
Are you kidding? Every note is welcome. It allows me to develop templates for you.
Download link again (ver1.4.1):
Kind regards
Piotr
Does the VR POI only work with the Umbrella template? I would like to use the Spartacus Light template with VR POI.
Hi Piotr,
Thank you for you quick reply.
I'm developer too, so I know that it's not always easy to track bugs.
Concerning the y position of central icon menu, I have checked it before posting my question.
The fact is that I can't find it... Maybe I'm just to tired. :-/
On the another hand, I noticed that you can not remove a lector file with VT Builder. Of course, it's easy to fix on xml itself.
Maybe I will contact you by pm to introduce myself and asking if you are interested to license your plugin to thousands of potential buyers.
Keep the good work.
HI,
Currently yes. The Umbrella is now a default template therefore the news is implemented first to it. But if you want I will try to add VR (text, photo, audio) to the Spartacus template as well.
Kind regards
Piotr
hi,
Check a settings.xml file - line 10
Good idea for the next update.
Of course.
Kind regards
Piotr
Hi Piotr,
I saw the new setting on the new version. I was confused believing that this setting exists before.
A poi_photo_width would be handy too if user want to limit size of light box.
Concerning the problem of poi video in vr mode, I saw that you answered on another thread saying that webgl can not support iframes.
It's possible. I used to have it on some projects developed under threejs. But on VT Builder case I don't how difficult it is to implement.
I tried to use animated hotspots like those that are on Krpano example package. https://krpano.com/examples/119/k…anihotspots.xml
But it seems that something is missing or conflicting with some variable or function and animation do not start.
Have a nice weekend my friend!
Czesc Piotr
nie bangla.
When I try to add flor plan both in jpg and png format nothing happens.
I have floorplans folder inside my tour.
any sugestions?
Marcin
Problem solved. Edge and IE were caussing it. Its working fine on Chrome.
Hy Piotr,
i have several questions for the umbrella template:
link to the tour: http://ginger.threesixty.at/
• how to remove the maps (navigation) icon in the right upper corner?
• how to prevent zooming in the tour?
• how to change the buttons in vr mode to the normal used ones?
• what is the heart symbol on the left under the logo doing?
• on ipad we get:
• in normal web browser we get:
Edit: on this I noticed the original file is in 'panos/1Eingang.tiles/preview.jpg'! the "1" before "Eingang" is lost...... strange?
I did a workaround and created this path additional, no it were found.
how can we solve that?
btw: your plugin is very nice, we love it! we just have to learn more in depth how to use the different functions
thank you
Hello
First of all... try update your Umbrella template. You ver is 1.3 but now is a 1.5.0 ver. Link do download is here: Umbrella template for Virtual Tour Builder
You mean the button on the right at the top?
Try update a Template.
The all graphics are in this locations:
poi/global/
modules/vrmenu/
You can change the graphics any time.
Each panorama can be added to favorites so that it can be easily found later.
on ipad we get:
ERROR: plugin[navi_fullscreen_ico] - style not found: navi_fullscreen_ico
ERROR: hotspot[vtb_z] - loading of 'panos/Eingang.tiles/preview.jpg' failed!
Probably there is no file on the server.
ERROR: loading of 'panos/2Salon.tiles/b/l3/3/l3_b_3_4.jpg' failed!
As before. Check if these files are on the server.
Thank you. If you have any questions, write here.
Kind regards
Piotr
Hello
Oh, thx didnt noticed this!
Quoted from "threesixty_at"
Yes
with the new template it works
Alles anzeigenQuoted from "threesixty_at"
poi/global/
modules/vrmenu/
so, in webvr its only possible to conroll the design by a picture, right? i just wanted to have the same hotspots as in the normal umbrella version
how can i do that?
on ipad we get:
i did the same workaround like below.
