Virtual Tour Builder (VT Builder) - free templates, modules, POI system and multi floor plans - NEW UPDATE (4.2.1)
  • Hi *smile*
    Zitat
    Yes
    Paste this code in a tour.xml file:
    <action name="hide_navi_open_ico" autorun="onstart">
     delayedcall(0.4,
     set(layer[navi_open_ico].visible, false);
     set(layer[navi_open_ico].x, -200);
    so, in webvr its only possible to conroll the design by a picture, right? i just wanted to have the same hotspots as in the normal umbrella version
    In normal mode, POIs are based on text icons, not graphical icons, so that everyone can change these icons in the settings.xml file, and that they are scalable, pixel effect on the retina screens and weigh less.
    how can i do that?
    If you click on the heart then in the navigation window, under the heart icon also, this panorama will be added to the list of favorites. This panorama will remain there even after reloading the page! Such a save system...
    Piotr
  • Hy!
    i tried your action but the map symbol is still there....... mhm
    the new version is online if you want to try.
    Thanks for your fast reply!
    *wink*
  • Hi *smile*
    In a settings.xml file (skin/templates/) change:
    hide_navipanel_onstart="false"
    to
    hide_navipanel_onstart="true"
    Below is a test:
    http://ginger.threesixty.at/tour.html?umbr…el_onstart=true
    Piotr
  • Hi
    How is it possible to stay updated with the themes and tourbuiler it self?
    I try to inform about all the updates in this thread. Add this topic to your favorites and then you will receive a notification. *smile*
    Kind regards
    Piotr
  • i noted something on IOS (Iphone 7), when tap on a hotspot sometimes the poi animation failed and then no click at any poi is possible then.
    This is unknown bug in a popup POI to panorama module, but only for "circle" type.
    Change:
    poi_to_pano_style="circle" to poi_to_pano_style="normal".
    I'm testing new solutions that won't have this error, I'll release a new version of the templates and I'll inform you about it here.
    Thank you for reporting this bug. *thumbup*
    Piotr
  • Hello everyone *smile*
    I've finished improve the Umbrella template.
    Many of you have asked for the possibility to add your own style animated hotspots to the panorama. Now it is possible! *thumbup*
    ver 1.6.0
    * NEW animated POI to panorama possibility *attention*
    In this place you can set a new style for POI to the next panorama. The sample styles are in this location:
    skin/templates/mainstyles/poi_topano_mainstyle.xml
    You can add you own style freely.
    Not all properties can be overwritten eg: scale, onclick, onhove r, onover, onout and for mobile devices - ondown, onup
    You can add you own new style for a hotspot 'normal' is a default.
    This work only if 'Floating POI style' is disabled.
    * rebuild all POI system - stability and performance improvement
    * rebuild arrow floating POI to panorama
    Below is a two examples.
    New arrow plugin:
    https://www.krpanostore.com/examples/tamplates/umbrella/1.6.0/
    New animated hotspot to the next panorama:
    https://www.krpanostore.com/examples/tamplates/umbrella/1.6.0/?global_modules.modules[m_arrowmode].aktyw=false
    New template is not ready to download yet, but any feedback are welcome. It's time to improve some things. If you like the new features, I will make the new version available to everyone interested - for free of course.
    Kind regards
    Piotr
  • First of all :
    Thx for this great tool, very helpfull.
    I have a few questions :
    Is it possible to edit the defaut size of the floorplan / radar window ?
    Is it possible to enable the radar / floorplan per default ?
    I'd like to use the spartacus dark template.
    And i have a suggestion if possible ?
    Would it be possibe to create the POI www links for each language ? So when the customer has the english setting i can link to our EN Product Website,
    When a customer has set the vr tour to german than i use the german poi links to our product site.
    Maybe an idea for all kind of pois (autio, Video inks ect ?)
    Kind regards,
  • Hi
    *smile*
    In this template -NO, but I will add this option at the next update.
    Radar is activated in modules section - globally - but NORTH must be SET for the panorama.
    I have to think about how best to do this. The topic is not easy, but workable.
    Kind regards
    Piotr
    The Spartacus-light and Spartacus-dark templates have been updated. *thumbup*
    see here:
    Spartacus-dark and Spartacus-light
    Main news:
    ver 2.2.0
    * hotspot_poi_topano_mainstyle NEW animated POI to panorama possibility
    Not all properties can be overwritten eg: scale, onclick, onhover, onover, onout and for mobile devices - ondown, onup
    * poi_to_pano_style popup to new scene style (normal or circle) - 'normal' is default
    * poi_size: NUMBER - POI size - use one or two walue separated '|' eg: poi_size="45" (POI width and POI height = 45) or poi_size="45|65" (POI width=45 and POI height=65)
    * poi_css_size: NUMBER - POI font size
    * poi_roundedge: NUMBER - roundedge POI (exept POI to new scene)
    * poi_panorama_roundedge: NUMBER - roundedge POI to new scene
    * poi_flip_color: BOOL - POI font color and POI background color switcher
    * poi_panorama_color: scene POI background color
    * poi_panorama_ico: scene POI icon
    * poi_info_color: info POI background color
    * poi_info_ico: info POI icon
    * poi_photo_color: photo POI background color
    * poi_photo_ico: photo POI icon
    * poi_audio_color: play audio POI background color
    * poi_audio_ico: play audio POI icon
    * poi_popup_color: www popup POI background color
    * poi_popup_ico: www popup POI icon
    * poi_youtube_color: youtube video POI background color
    * poi_youtube_ico: youtube video POI icon
    * default_map_width window width for map/floorplans/info box
    * default_map_height window height for map/floorplans/info box
    * vr_poi_png_name name POI graphic
    * vr_txt_width NUMBER - max width for txt POI in VR mode
    * vr_txt_bgroundedge NUMBER - bgroundedge for txt POI in VR mode
    * vr_txt_bgshadow bgshadow for txt POI in VR mode
    * vr_txt_oversampling oversampling for txt POI in VR mode
    * vr_photo_width NUMBER - max width for photo POI in VR mode
    * hotspot_poi_topano_mainstyle popup to next scene style (normal/circle)
    Both template for the VT Builder system can be downloaded, for free of course from here:
    Spartacus-light
    Spartacus-dark
    All comments are welcome.
    kind regards
    Piotr
    p.s. map/plan/info box width and height can freely adjust now *thumbsup*
    I'm wondering if this plugin has support to create polygons within the pano. We have a use-case where property owners would like to create a boundary around a tract of land. Ideally we'd be able to click on a few points inside the pano and have the polygon drawn and saved. Is this possible?
    Thanks.
  • Hello
    For now this is not possible. Sorry. We wait for polygonal VR support.
    Kind regards
    Piotr
  • Hi Phil
    do you have plans for create a solution for 360 video tours?
    we are highly interested in such a feature!
    Of course, yes. We are waiting for droplets to start supporting 360 video. 360 video scene can now be added manually in XML code.
    best regards
    Piotr
  • Hy Piotr,
    do you can explain the WEBVR Hotspot a little bit more....i dont get it why in VR Mode no external links are possible.....
    it seams they managed it:
    "Navigation Links + Hotspots still clickable in WebVR, as is a Call-to-Action feature opening a specific URL. Clickable hotspots include the ability to open a separate URL — outside of the 360 environment. This is great for retail, tourism, real estate, etc."
    on http://www.instavr.co/solutions/vr-outputs/web-vr
    Do you know when new droplets are coming for 360 Video?
    thanks a lot for your patience
    *wink*
    Phil
