Hi
Below is livepano example with surround sound. Video embedded on the panoramas have the 3d sound effect ![]()
http://www.krpanostore.com/examples/livepano/
This example also works on mobile devices in VR mode
Piotr
Hi
Piotr
i think the effect is much too strong, specially in the first pano.
when you turn away from the fountain the sound almost disappears,
and inbetween you have quite hard steps....
Really nice again!!
The last example jacuzzi seems not to have moving stuff going on, i just visited on iphone..
I wonder which methode you used for the moving parts.
Maybe a hint?
Cheers!!
Tuur ![]()
This effect can be set individually. Just as in our HTML5-VR Audio Plugin
QuoteJust as in our I wonder which methode you used for the moving parts.
Maybe a hint?
This is quite simple with our Virtual Tour Builder. See here - YouTube video
Piotr
Ah i see now ![]()
Clear!
I'll promote your tool to some clients.
I''m sure they'll like it.
Tuur ![]()
i want to know how you make video in this pano? do you use ptgui output a part pano image, shoot video, then use aftereffect mask video into image? finally use klaus calc_pos_from_fov-yaw-pitch-roll action?
Really cool stuff!
I remember, I've seen the cat in the real estate game you made maybe three or two years ago and I wondered then how the heck the cat was put inside)))
Hi
Good job!
how are you get to match colors in the photo and video?
what model of camera do you use?
Hi
Video was recorded using an SLR (5D Mark II, 24-105 L) and processed in AE and PS. We do not use the mask for performance reasons.
Yaw, Pitch, Roll, FOV action is available
. If you are using settings from PTGui, you will be satisfied. See attachments.
Good job!
We use Photoshop to edit colors of video. We work on Canon EOS 5D MarkII.
Best regards
While video hotspots are shown to work in VR mode, is there a way to apply them for true stereoscopic VR? I'm not seeing a way to do that...?
Hi
No, because Krpano droplet not support "true stereoscopic VR". Such things need to be done manually in the code (stereoscopic panorama).
There is no such tool in a market.
best regards
Piotr
Tnx Piotr! What a shame! So many limitations yet with webVR,
Hi
Livepano works very well in vrmode.
If you want a stereoscope livepano then you need to have two identical videos from different places. Same animation, lighting, scene ... It's practically impossible to make two the same videos. Set them on the panorama in the same place and finally synchronize two separate videos in milliseconds in a krpano code asynchronously (performance is decreasing).
I think that the problems with making stereoscopic livepano exceed the benefits. And we would have to be able to add separate objects to the left and right eyes in the scene.
Think about it...
best regards
Piotr
Tnx Piotr, that's an interesting point. Here's something to consider: I'm actually creating all of my virtual tours using 3D Studio Max / V-Ray: so I don't have the physical hardware limitations of a stereo video camera rig! This means that for fixed point renderings I'm able to fully create/control the left and right output.
Knowing this, what are my options now in terms of adding and editing the video hotspots for the right eye scenes?
