hi,
my Bing maps html5 seems not sharp on retina display,
usually i use a double size for plugin and set scale="0.5" to get retina sharpness
but here i can't figure out how to get a sharper map,
is a parameter inside the plugin itself not implemented and need update
or is there a way around ?
Thanks for help or infos
BING MAPS :
The new Bing Maps V8 SDK has much better mobile support and automatically detects the screen resolution and uses high DPI map images when needed.
https://blogs.bing.com/maps/2015/02/1…ps-ajax-control
seems the map version used in plugin is 7, please update to 8 ![]()
z
