is there a way or trick to load 2 panaoramas simultaneously?
i wanted to load 2 spherical panorama that one of them is inside of the other one and by using masking thechniques try to show the half of inner panorama.
is this possible?
is this possible?
currently this would be only possible by using distorted hotspots,
but the masking in this case is not very efficient and doesn't always...
please have a look at this threads:
Masking with 2 images and an alpha mask image, is it posble ?
Example/Tutorial - interactive area in the pano (aligned distorted hotspot)
Klaus,
Will there be a way to show different panoramas simultaneously ? in the same area ? and maybe, even better, in different area ? ![]()
I'm sure this is not until 1.0.9, but it could be so wonderful !
To make thing like this but with a better integration : http://www.nicolasburtey.net/visite-virtuelle-en-split-screen/
already planned and partial also in work, but not for version 1.0.8...
http://www.nicolasburtey.net/visite-virt…n-split-screen/
great example! ![]()
great example!best regards,
could ypu please share the XML file of this example or where could i find it?
i'm to finish a project and it is so vital to me.
thank you Klaus
have a look here:
Can a split screen pano be done?
or here:
https://krpano.com/examples/javascriptsync/
