Hello
Tell me how to extract parameters from
Bgshadow = "40 32 18 36 0x00FFFA 0.5"
Bgroundedge = "99 99 00 00"
Bgborder = "22.74.22.67 0xC57200 0.78"
(A = 40, b = 32 ... e = 0x00FFFA ...)?
Subtxt do not work, the length of the text can be different.
Hello
thanks for the answer! But how?
copy(Border_1,layer[layer_San].bgborder);
Border_1 = 2,10,120,5 0xFFFFFF 0.8 There are no separators
a=2, b=10, c=120, d=5, e=0xFFFFFF, f=0.8 ?
bgborder="34,07,06,14 0x8C879D 1
Thank you!
top_width - Lower underscores do not work.
topwidth - it worked!
30 76 81 27 0xC8FF00 0.5 - Yes, it shares
15,20,11,05 0xD200E0 0.5 -
no, the comma is not a delimiter and outputs so
a=15,20,11,05 b=0xD200E0 c=0.5
Found!
15,20,11,05 0xD200E0 0.5 -->
txtreplace(dstvar,layer[color].bgborder,',',' '); - Substitution by a comma for a space -->
15 20 11 05 0xD200E0 0.5
Top_width must work in the same exact way as any other name not beginig with a number...
So there you must have another syntax error.
Top_width должен работать точно так же, как любое другое имя, не начинающее с номера ...
Таким образом, вы должны иметь другую синтаксическую ошибку.
Yes, syntax error, everything works! Thank you!
