Samsung Galaxy S8+ not detected / working with VR
    I have a Samsung Galaxy S8+ (along with, I believe, many others). For some reason, it doesn't work with VR - and when I go into setup, it says Device Unkown and Screensize 5.0 inch. Even with the mobilevr_database_url defined, nothing seems to change.
    I am testing using the testingserver - I don't know if there is any reason to believe it would behave differently from a "real" webserver....?
    that means that device is currently not in a Cardboard device database.
    Can you provide information about your Samsung Galaxy S8+, then I can try adding it?
    The user-agent and the real screen-sizes would be required to be know. According to a web-research the device name should be 'G955F' but seeing real and verified data would be better of course.
    Btw - what do you mean with 'Even with the mobilevr_database_url defined, nothing seems to change'?
    Have you set a link to custom database where the S8+ is listed?
    Because when mobilevr_database_url is not, the https://dpdb.webvr.rocks/dpdb.json database will be used by default (see here - mobilevr_database_url) and in that database there is currently no entry for 'G955F'.
  • Can you provide information about your Samsung Galaxy S8+, then I can try adding it?
    How do I go about figuring out these details ? Isn't it very strange that the flagship phone from samsung isn't allready in this database ?
    I just tried explicitly adding the attribute - didn't realize it defaulted to it :)
  • Found this by googling:
    51Degrees has detected User-Agents for the Galaxy S8 and S8+ and we've looked into the hardware model numbers in greater detail to discover that the SM-G950U, SM-G950F and SM-G950W relate to the Galaxy S8 whilst SM-G955U, SM-G955F and SM-G955W relate to the Galaxy S8+. With Samsung devices the last letter of the model number usually indicates to what market or mobile carrier the device belongs to. The 'F' in the models SM-G950F and SM-G955F mean they represent the international versions of the Galaxy S8/S8+. The 'U' and 'W' markers represent models introduced to the Asian markets.
    S8 has a 5,8" screen and the S8+ has a 6,2" screen....
    No, It don't think that's that strange...
    You could request an database entry here:
    https://github.com/WebVRRocks/webvr-polyfill-dpdb
    It seems someone has already added the S8+ but only the US version - the 'SM-G955U':
    https://github.com/WebVRRocks/web…mment-313925532
    Personally I think it would have be better just to add 'SM-G955' without the 'U' to cover all versions - at least in the next krpano release it will be added this way to internal device database.
    Btw - if you don't know how to get the user-agent of your browser/device, just use sites like this:
    http://whatsmyuseragent.org/
    or sites like this which provide also other interesting information:
    http://webglreport.com/
    https://browserleaks.com/webgl
