It seems there is a bug in Krpano 1.0.8 beta 9 (I am using krpano 1.0.8 beta 9 DEV (build 2009-10-29) )....
When view.maxpixelzoom is defined at first, it makes the view to open at FOVMAX value (in the example above, fovmax=150 instead of fov value)... note: the zoom limit from maxpixelzoom works as expected...
try using the latest krpano.swf (one is include in the 1.0.8 beta 9 tools download),
there all should work correct...
but note - when the pano resolution is too low or the window too large, then the maxpixelzoom can
already change the starting fov because it can be below the maxpixelzoom limit,
