is it possible to put a trasnparente grid on a spherical panorama as a reference to fix the hotspots?
Suso
Suso
Ok thank you very much,
I put the event code in my xml and nothing happens, what should happen?
Thanks for your attention
Suso
try to change your main xml like this
<krpano debugmode="true" showlog="true">
<events name="click4angles" keep="true" onclick="screentosphere(mouse.x,mouse.y,mouseath,mouseatv);roundval(mouseath,3);roundval(mouseatv,3);debug('ath=',mouseath,'atv=',mouseatv);" />
.... your stuff ...
Ok, this works, but what I'm really looking for is a grid over the scene or guides to adjust the perspective of my hotspots.
Thank you.
Regards
Suso
download this pic:
http://www.virtualtuur.com/krpano/grid/1/grid.png
Now you can burn it in your pano, with photoshop for example and use that
OR
make cube faces from it as hotspots.. and overlay.
simple, and sloppy example of that.
xml
http://www.virtualtuur.com/krpano/grid/1/tour.xml
Edit:
if you press T (keyboard) , then you find my little toolbox.
https://krpano.com/forum/wbb/inde…74910#post74910
use the numbers section, or maybe better the distorted hotspot editor to find some relevant numbers etc..
Hope it helps
Tuur ![]()
i quickly made a dynamic grid.
UPDATED!!
http://www.virtualtuur.com/krpano/grid/3/
press G to show/hide the grid.
Is that what you mean?
include the grid.xml in your project.
grid.xml
I will add this to the Toolbox at a later moment.
updated: DONE!
But here you can of course also press T.
The numbers section could be help full.
edit:
yes.... i was a bit sloppy on the line position, but that will be fixed.
UPDATE:
FIXED
Hope it helps!
Tuur ![]()
Thanks Tuur and Thanks Taurus forma your help
Suso
