This is a demo version on google disk, I hope there will be no problems
Creating Floor Plans.
I removed the urls for googlemaps.js and bingmaps.js from vtourskin.xml action "skin_startup" and removed the js files from the plugin folder. It seems there is no problems with this. Do you think there could be any problems or is it safe to do so? I don't want my tour to load the google api, only using floorplan plugin.
Thanks for your input.
Best,
Max -
the googlemaps.js and bingmaps.js plugins have nothing to do with the floor plans plugin. You can delete them. -
Thanks for quickly reassuring
Hi, use the native krpano tool to align north.
Disable in the plugin "KEEPVIEW" and set in the tour loadscene_flags = "KEEPVIEW"
You will no longer need to align the radars in the plug-in, just initially correct the compass. If you set the correct north everywhere, the radar will automatically show correctly and should work normally in vr modeHey Alex,
before 1.20.10 I created my tour, aligned all scenes using floorplan plugin, positioned all hotspots, now stumbling over this vr keepview problem.
Is there a way to fix it without prealigning all scenes and hotspots from scratch?
//edit: The Keepview settings work in simulated-browser-webvr mode by the way.
Thanks and best,
Max -
Hello, fix the alignment in the Krpano editor and set the prealign=true in the hotspots
Ahhhhhh! Thanks for the fast reply. Wasn't even aware of hotspot prealign="true"
Hi all! This is a small update of Floor Plans v1.47
- When switching plans, moving the plan with the mouse was not limited. fixed.
- When navigating by points in the plan, the plan could move beyond the window dimensions. Fixed
Hello!
Small update Creating Floor Plans v1.48
Now it has become easier to put points on the plan, especially with large volumesDownload link use your pin_flpl.xml !
This is a test version. The plugin has been completely redesigned and works with krpano version from 1.21 I have not made a description yet, but I recorded an example on YouTube .
You can download demo plugin. This is a fully working version, only there is an inscription - demo
Now you do not need to enter a password. But the plugin is tied to your krpano license
a window with a plan is a frame in which a flat pano with a plan opens. -
Great!
Is it possible to use this plugin in depthmaps too?
Hello! Thank you!
Yes, you can use it in the 3d model, only the click on the points will need to be reassigned to the code that you use to navigate in the tour with a depth map.Here is my example
Hi all! Creating Floor Plans v2.1 update. krpano version 1.21
- The plugin uses layers for plan images.
- Setting the width and height, x y values of the plan window in the editor.
- The height of the plan window is set automatically in proportion to the width of the plan
- If there are several plans, you can set the window width for each plan individually.
- The plan expands to the set width but not more than the width of the screen
- You can visually change the radar scale and save changes for each plan.
- Set the plan to close if the panorama is not on the plans, and show the plan if the current panorama is present on the plan.
- Ability to display the drop-down list of plans separately and customize its design.
- Ability to create your own buttons and assign them to open the desired plans.
The navigation module is a paid add-on for those who have already purchased the plugin. Included in the plugin for those who purchase the plugin:
- Automatic placement of arrows at created points.
- Manual selection of transition arrows.
- Adjust the size, position height and inclination of the arrows.
- Ability to correct the position of each arrow.
- Navigation by clicking in the direction of the arrow.
- Ability to visually change the radar scale and save changes for each plan.
- Ability to replace the arrow image and customize your own style for the arrows.
An example of how the new version of YouTube works.
Hi all! Creating Floor Plans v2.2 update. krpano version 1.21
- Added a panel with advanced settings, where you can disable/enable various options and change some project settings.
- Added an input panel for individual icons for a point (before and after viewing the panorama), disabling keepview for an individual point. A panel appears at each point in edit mode if this option is enabled.
- Added setting width/height for mobile devices
- Added a switchable option - Hide the plan window if there is no open panorama on the plan, show the plan window if there is a current panorama on it.
- Moved the action of creating compass marks to the file style_Flpl.xml (open source), you can customize it at your discretion.
- Fixed the problem of entering color in the editor line.
Hello, I have purchased and used your Floor Plans plugin, but I am currently facing an issue. When using it on a mobile phone, I click to open the map, and then clicking on the map area brings up an info notification as shown in the picture. How can I prevent this notification from appearing? Please guide me on how to disable that notification. I do not want it to appear.
Hello, I have already sent you an answer by mail, I will duplicate it here.
The bug has been fixed in the updated version, download the latest update here , Use your key file from the mail!!! -
Thank you very much
Hello!
Awesome plugin! I am really enjoying this plugin.
I think I found out one possible bug?
Scene points have three states - start, viewed, active.
These states seem to work fine except for the first loaded panorama.
For example from the example above
- https://novosibpano.ru/examples/terrasa/
If I have load "Living Room" as my first loading panorama,
The status of "Living Room'"s scene point of turns to "active" (green).
However, if I load another panorama, the status of "Living Room'"s scene point of turns to "start"(red) instead of "viewed"(gray).
When I load "Living Room" again and then another panorama (in thise case "Corridor"), the status of "Living Room" turns to "viewed"(gray), which is as expected.
This happens to my tours too.
Can you please check this?
Cheers,
Hyung
