pinch-in pinch-out does not work on Edge.
But IE11 works.
Is it a problem with Edge and Windows 10?
Thank you.
But IE11 works.
Thank you.
there is no known problem, touch control was working fine on Windows 10 devices with touch-screens (in Edge and IE11).
What device do you use?
And what browser and krpano version?
Link to the example?
thankyou klaus
For example,
Microsoft Surface Laptop Lenovo Yoga 2 11
Touch screen model.
Windows10 Home 1803(17134.345) Microsoft EdgeHTML 17.17134 krpano 1.19-pr16(build 2018-04-04)
krpano Examples https://krpano.com/tours/paris/
I am creating a store application in C#.However, because the component of the Web view is an Edge, it does not work, so it's in trouble.
I am happy if I know something.
Thank you.
sorry, you're right - I have updated my Windows 10 touch test device now and with the latest update the touch-support wasn't working anymore.
The reason is that the 'pointerEnabled' property has been removed in the latest MS Edge update. And krpano was using that for testing if the IE/Edge browser is supporting touch control.
In the next krpano release this change will be included/respected.
For a manual fix for the moment add the following line in the html file before calling the embedpano() function:
This 'restores' the missing pointerEnabled property.
please see also here - in Chrome 70 there was a similar change that requires also a workaround:
Chrome 70.0.3538.77 breaks KRPano touch functionality
thankyou klaus
It worked so well!!
I appreciate it very much.
Thank you.
