Splitscreen multi resolution
  • Hello everyone,
    I created a before/after thanks to Krpano's splitscreen module. Can someone tell me if it is possible to load the 2 panos in multi-resolution???
    If so, do you have an example of XML code?
    Thank you for your help.
    Xavier
    Here is my link : http://www.360pano.be/beforeafter/
    <display stereo="true" stereooverlap="1.0" />
    	<image stereo="true" stereolabels="1|2">		<cube url="panos/pano%t_%s.jpg" />	</image>
    yes, the stereo-support works for multires too.
    Will stereo work for panoramas with different resolutions and different breakdown into levels and tile sizes? For example, the 1st panorama:
    multires="664,664,1328,2656,5312,10624,21248"
    2d panorama:
    multires="1024,1024,2048,4096,8192,16384"
    How do I describe each panorama its own multires? I need this for the implementation of "Before-After", taken in different resolutions. Resize to the same resolution loses the sense of showing changes. In addition, the panoramas are already tiled and uploaded to the server. I only need to make a separate html and xml to show the changes.
    And will the zoom limitation and synchronization work according to maxpixelzoom if this implementation is possible?
    Livepano.ru
    Edited once, last by Rodeus (August 22, 2020 at 6:37 PM).
