Pano Viewer Disappears
    I'm having a problem where when I try to load a specific scene in response to the selection of a treeview node, the entire viewer just disappears. Any ideas as to why this is happening?
    Default.aspx
    <%@ Page Title="Home Page" Language="C#" MasterPageFile="~/Site.Master" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
    <asp:Content ID="BodyContent" ContentPlaceHolderID="MainContent" runat="server">
    <div class="container-fluid">
    <script src="Krpano/vtour/tour.js"></script>
    <div class="row">
    <div class="col-sm-3">
    <h3>Hello from col 1</h3>
    <asp:TreeView ID="TreeView1" runat="server" OnSelectedNodeChanged="TreeView1_SelectedNodeChanged">
    <Nodes>
    <asp:TreeNode Text="Option Set 1" SelectAction="None">
    <asp:TreeNode Text="Option A" Value="1A"></asp:TreeNode>
    <asp:TreeNode Text="Option B" Value="1B"></asp:TreeNode>
    </asp:TreeNode>
    </Nodes>
    </asp:TreeView>
    <asp:TreeView ID="TreeView2" runat="server" OnSelectedNodeChanged="TreeView2_SelectedNodeChanged">
    <Nodes>
    <asp:TreeNode Text="Option Set 2" SelectAction="None">
    <asp:TreeNode Text="Option A" Value="2A"></asp:TreeNode>
    <asp:TreeNode Text="Option B" Value="2B"></asp:TreeNode>
    </asp:TreeNode>
    </Nodes>
    </asp:TreeView>
    <asp:TreeView ID="TreeView3" runat="server" OnSelectedNodeChanged="TreeView3_SelectedNodeChanged">
    <Nodes>
    <asp:TreeNode Text="Option Set 3" SelectAction="None">
    <asp:TreeNode Text="Option A" Value="3A"></asp:TreeNode>
    <asp:TreeNode Text="Option B" Value="3B"></asp:TreeNode>
    </asp:TreeNode>
    </Nodes>
    </asp:TreeView>
    </div>
    <div class="col-sm-9" id="pano1" style="height:800px">
    <h3>Hello from col 2</h3>
    <script>
    function initialPano()
    embedpano({ swf: null, xml: "Krpano/vtour/tour.xml", target: "pano1", localfallback: "http://localhost:8090", html5: "auto" });
    var krpano1 = document.getElementById("krpanoSWFObject");
    krpano1.call("loadpanoscene('tour.xml', 'scene_PanoImg10a', null, null, NOBLEND);");
    </script>
    <script>
    function updatePano(sceneID)
    krpano1.call("loadpanoscene('tour.xml', " +sceneID+ ", null, null, NOBLEND);");
    </script>
    <script>
    function createSceneID()
    var tv1 = document.getElementById("TreeView1");
    var tv2 = document.getElementById("TreeView2");
    var tv3 = document.getElementById("TreeView3");
    var sceneID = tv1_Data.selectedNodeID.value + tv2_Data.selectedNodeID.value + tv3_Data.selectedNodeID.value;
    if (sceneID = "1A2A3A") {
    sceneID = "scene_PanoImg10a"
    else if (sceneID = "1B2A3A") { sceneID = "scene_PanoImg02a" }
    else if (sceneID = "1A2B3A") { sceneID = "scene_PanoImg09a" }
    else if (sceneID = "1A2A3B") { sceneID = "scene_PanoImg01a" }
    else if (sceneID = "1B2B3A") { sceneID = "scene_PanoImg08a" }
    else if (sceneID = "1B2A3B") { sceneID = "scene_PanoImg04a" }
    else if (sceneID = "1A2B3B") { sceneID = "scene_PanoImg03a" }
    else if (sceneID = "1B2B3B") { sceneID = "scene_PanoImg06a" }
    return sceneID;
    </script>
    </div>
    </div>
    </div>
    </asp:Content>
    Default.aspx.cs
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Web;
    using System.Web.UI;
    using System.Web.UI.WebControls;
    public partial class _Default : Page
    protected void Page_Load(object sender, EventArgs e)
    ScriptManager.RegisterStartupScript(this, GetType(), "initialPano", "initialPano()", true);
    var nodeValue1 = "1A";
    foreach (TreeNode node in TreeView1.Nodes)
    if (node.Value == nodeValue1)
    node.Selected = true;
    var nodeValue2 = "2A";
    foreach (TreeNode node in TreeView2.Nodes)
    if (node.Value == nodeValue2)
    var nodeValue3 = "3A";
    foreach (TreeNode node in TreeView3.Nodes)
    if (node.Value == nodeValue3)
    protected void TreeView1_SelectedNodeChanged(object sender, EventArgs e)
    ScriptManager.RegisterStartupScript(this, GetType(), "updatePano", "createSceneID()", true);
    ScriptManager.RegisterStartupScript(this, GetType(), "updatePano", "updatePano(createSceneID())", true);
    protected void TreeView2_SelectedNodeChanged(object sender, EventArgs e)
    protected void TreeView3_SelectedNodeChanged(object sender, EventArgs e)
