slicing gigapixel performance
  • hi
    i just built a 36gigapixel image and now i am slicing it.
    been 12hours now and it is at
    krpano makepano tool 1.19-pr16 - 64bit (build 2018-04-04)
    - using config: vtour-multires.config
    processing - 2019.08.03 17.40.41 DSC03691 Panorama-1
    - converting sphere to cube format...
    1/7 loading... 66%
    when i look at system performance (i am writing this in the same pc and i got no issues at all) it takes only 12%cpu and 421mb RAM (although it might be leaking because the overall system shows 6.1gb in use)
    i have i7 with 8 cores and 16gb ram
    disks are "sleeping"
    the 12% seems to me 100 / 8 = 12.5% and would mean 1 cpu but, when i look at the cpu occupation graph one of them is clearly more busy than the others (<- just edited this info from original post)
    i'd like this to go faster
    is there some setting?
    the config is the standard one. i just changed the temp folder.
    i'm using the multiresvtour droplet
    thank you for your help
    Rui Pedro
  • cancelled at 67% (almost 24h passes) and 3h ago changed the temp file folder to my ssd drive
    it is at 63% now after 3h30m
    edit - new info:
    not much difference between sata and ssd at this time
    1/7 loading... 67%
    update:
    this morning was at 69%
    now i went to check it and from 11/Ago 17h52 till 13/Ago 19h08 i got
    1 323 875 swap files
    and why 19h08?? because windows rebooted !!!!
    *cursing*
