That's already fixed,
Thanks, Klaus!
Thanks, Klaus!
Hello Klaus,
I upgraded my Panotour Pro from KRPano 1.19-pr16 to 1.21 and the map window seem to be not working anymore. It just show a blank white screen. Do you know why?
the Update Package doesn't change or modify anything inside Panotour Pro, it changes only the output files, output templates. That means the Update is not the reason for this!
The not working map-window is probably related to Google Maps and some changes there (either Google Maps API has changed or the internal Panotour Google Maps API key isn't working anymore).
I would test krpano 1.20.11(latest release, tehre are several ones) rather than 1.21
I had some problems with 1.21 and PTP
Best,
Pablo
Excuse me
1. I accidentally deleted the Panotour pro software and need to reinstall it. However, MAC OS has been updated to Ventura 13.5.2 version and cannot be installed successfully.
My computer is an iMac Pro 3.2GHz 8 core Intel Xeon W
2. Can I install Panotour pro software on MAC with M1 and M2 processors?
It would be interesting to know what operating systems and versions Panotour still supports to make the move soon, thank you
I have been able to install and run Panotour on my Macbook Air M2 on Sonoma 13.5 by opening terminal and running this
sudo arch -x86_64 /Applications/Panotour\ Pro\ 2.5.app/Contents/MacOS/PanotourPro
However, I can't get the Krpano update to install so I'm stuck with 1.19.
I also need to install all the plugins directly into the app. It does not see the user folder.
I'd really appreciate some help if anyone knows how to get the app to see the user folder for plugins and the krpano update!
Thanks!
Hello Klaus,
Anyone can still open the map from Panotour Pro with any version of krpano?
I ask because on my old computer my map also not show google maps anymore but I did update to krpano 1.21.
Hello Klaus
My last problem was that I accidentally deleted the Panotour pro software and needed to reinstall it. However, MAC OS has been updated to Ventura 13.5.2 version and cannot be installed successfully. My computer is an iMac Pro 3.2GHz 8 core Intel Xeon W
The latest solution is that I took the computer to Apple, first downgraded the operating system back to the old version, then installed Panotour pro 2.5 successfully, and then updated the operating system, which is currently Sonoma14.3.
Please ask Klaus
My computer often crashes when I run Panotour pro recently. I plan to buy a new computer. Can I install Panotour Pro 2.5 on the new MAC equipped with Apple M2 Max or Apple M2 Ultra processor and the operating system is Sonoma 14.3? Do I need to purchase or update krpano during the installation process?
Please give me some advice
Is there any valuable experience in successfully installing Panotour Pro 2.5 on a new MAC equipped with Apple M2 Max or Apple M2 Ultra processor, macOS:Sonoma, can you share with me?
I'm willing to pay to learn about effective software installation methods.
Ken Hsiao
I haven’t personally installed Panotour Pro 2.5 on a Mac with an M2 Max or Ultra, but I’ve heard that older software can sometimes run into compatibility issues with the latest hardware and macOS versions. You might want to check if there's a specific update or patch for Panotour Pro that supports newer Macs.
Hello Klaus
The latest solution is that I took the computer to Apple, first downgraded the operating system back to the old version, then installed Panotour pro 2.5 successfully, and then updated the operating system, which is currently Sonoma14.3.Please ask Klaus
Reinstall KRpano 1.20 for best panotour, 1.21 is not optimized for panotour many plugin not work
The latest stable version compatible with Panotour is 1.20.11. It’s very stable in Windows 11. It’s important to keep update this version for any security patches. Or a new version compatible with compatible code. Panotour community will support this.
