I'm completely lost. I see no tutorials on where to put the codes for various functions.
I have 1.19, do I need to purchase a new licence to upgrade to 1.20?
Thanks.
Thanks.
look at the docs and read the XML file from the examples
only if you want these new features:
Depthmap Support
Spherical / Cylindrical / Partial-Pano Multi-Resolution Support
Postprocessing Plugins
Panotour Pro Update
Thanks.
Thank you sir.
I don.t see the code where it makes your wife stop nagging you about painting the house.
Happy Friday.
look at the I have 1.19, do I need to purchase a new licence to upgrade to 1.20?
Depthmap Support
Panotour Pro Update
Thanks.
[quote='chrissileo','index.php?page=Thread&postID=79880#post79880']Thanks.
https://krpano.com/examples/Hey Tom thanks for the post.
But good lord Im lost. I must be missing it but where do the codes code? Or are each even its own xml file? Im reading the docs and see there's sintax and code but I just dont get where to pt the commands. And I can only add hot spots and change the icon but cant figure how to draw shape hot spots and add pop ups.
Is there anyone out there in KR Pano land that does this for work? Ill get my client to pay!
thanks
Chris
<scene>
<preview />
<cube />
<!-- <hotspot /> here -->
you need to add the hotspots into the scene
chrissileo, I hear you. I'm in the same boat, I'd like to learn coding, but it's virtually impossible with only this documentation. What I think is lacking is a guide explaining the basics, the operation principle of coding. Just a list of commands, with no explanation on how to use them, is quite useless for beginners.
while krpano allows you to achieve stunning results without programming
it still needs time and programming knowledge to dive into deeper waters.
if you never coded anything at all,
you should use dedicated websites / courses to learn basic programming principles, first.
also understanding web technologies (html, css, js) helps a lot
after that... be sure, the documentation is really great.
just study the examples and check the documentation for things you dont understand.
copy the examples in a webfolder so that you can change things and experiment.
start with simple things like creating layers and hotspots... first by xml, then dynamically by actions
nothing goes over trial and error :)
also with a real example (not working, yet) you always get help here
see https://www.w3schools.com/ to get started.....
You can simply use vrTourSoft. https://www.vrtoursoft.com/
This is the automatic editor for krpano.
No programming knowledge is required from you. This is a WYSIWYG editor. Everything is intuitive.
There are also good lessons on site.
You can also use all your programming knowledge and any code developments. The editor allows you to use any code or plugins compatible with krpano.
Until the end of 2109, a free period for testing is 1 month.
