Hello,
The cursor/tracker that activates the hotspots is not working on oculus browsers. It works on samsung browsers though. Krpano version is 1.20.1.
Any solutions/suggestions for this?
Thank you.
Oculus device - cursor/tracker not working
Do you mean the white cross in the center?
Yes. That one.
Look here https://krpano.com/plugins/webvr/#vr_controller_support
change to
or add this action
Code<action name="disable_vr_controllers" autorun="preinit"> callwhen(plugin[webvr].loaded, set(plugin[webvr].vr_controller_support, false)); </action>Piotr
That really helped. Thank you very much spacerywirtualne.
